Console Odometer Button HELP!!
Old Dec 23, 2010 | 06:54 AM
WIDERGLIDER's Avatar
WIDERGLIDER
Default Console Odometer Button HELP!!
Looking for some help,
When I removed my dash, while disconnecting the wiring harnesses, everything went smoothly until I got to the rubber odometer button on the side of the dash. This button cycles through the information on my dash console.
While unscrewing the button, the inside wires connected to it burst apart, a couple of springs went flying, and the mechanism dismantled. I found all of the pieces and believe I have the button assembled again, but I have no idea how the wires are connected inside this mechanism. There is NO information in the service manual about how this goes back together. I played with it for a while, but can't seem to find where the wires connect inside the mechanism. Here's a couple pictures...HELP!
Attached Thumbnails Console Odometer Button HELP!!-img_0207.jpg   Console Odometer Button HELP!!-img_0208.jpg
Old Dec 23, 2010 | 08:06 AM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
buy a new switch and solder it back in. only solution
Old Dec 23, 2010 | 08:17 AM
WIDERGLIDER
Charlie, is it possible the switch is pre wired for options my bike doesn't have? I see no terminals to connect those wires to...maybe the two wires were just resting in the housing?
Old Dec 23, 2010 | 10:48 AM
dawg's Avatar
dawg
Isn't that the odometer reset switch you are talking about?
Old Dec 23, 2010 | 11:36 AM
WIDERGLIDER
Yes, dawg, it also cycles through the different console options like clock, trip A/B...
Old Dec 23, 2010 | 11:48 AM
skratch's Avatar
skratch
i think i'd go with a new switch too. they are only $15.00 at the dealer, and then you know it would be right.
on my 07, my speedo would go crazy. when i turned the ignition on, the speedo would go from zero to max and then back to zero. then the odometer would display trouble codes. turned out the switch had an internal short in it causing it to go into diagnostic mode. dealer replaced the switch (under warranty) and all was good again.
Old Dec 23, 2010 | 01:43 PM
FastHoss's Avatar
FastHoss
Try it before you button everything back up,if you can,may not need a new one.
Old Dec 23, 2010 | 04:52 PM
chamokie's Avatar
chamokie
I would replace the switch. If it fell apart it was an issue waiting to happen. Throw it away and get a new one.
Blk80bike
Electrical/Lighting/Alarm
Sep 25, 2016 08:09 AM
gahendo
2014-2024 Touring Models
Apr 7, 2014 12:00 PM
WIDERGLIDER
Dec 25, 2010 02:27 PM
sgnden
Aug 3, 2009 09:37 PM
blueflht
Sep 1, 2008 06:24 PM
