i will be trying the remote door opener in the fairing this week. does anyone have a foto of the wires soldered to the back of the switch on the circut board? not sure were to solder the wires
I was going to ask the same question..lets stay tuned for answers...
chula there are a number of posts on this but the short of it is you take a remote door opener split it open remove the circut board. then solder 2 leads to the button on the backside of the board. then using a momentry switch (i will use the speedo reset button) mounted on my tank dash. connect the 2 wires to the switch. push button door opens!
Never heard of that hook-up before...Thought you needed some current...If it works your way, that's a simpler and easier way....
the current is the battery on the circut board. 2032 watch battery. my remote in my car is 3 yrs old still same battery! put the board in the fairing and the button in the center dash on the tank. just need to see were the wires are soldered on the circut board
Are you getting double duty out of the speedo reset button or are you adding another button?
no im using a separate button. im just adding another speedo button because its small and watertite. chula ill post fotos once i get the info and the button
Sounds like a plan....Have any HD part numbers for the switch and rubber cover?
Going out side now and tearing open a spare door opener to see if I can figure the wiring out...
