I know the science behind ABS. It was actually a part of a advanced driving school I took years ago. I can tell you that it would have prevented my last accident. I locked up the rear tire during an emergency stop and it came off track with the front tire. Instictively, I though "oh ****" I need to stop the lock up before I crash. I let off the rear brake, the rear tire gained traction again. The rear tire started going back in the right direction, but my body didn't. I high sided and still have the scar on my knee to remind me. Sure, I could "learn" to ignore my instincts and not let off the brake when the rear tire is locked up. I have practiced but the tire stays in line every time. The complete maneuver is too dangerous to "practice" doing right. ABS would have kept the rear tire from locking up. If it had been offered on the Dyna I just got, I would have gladly paid extra.
BTW, according to the experts if your rear tire locks up and comes out of alignment with the front tire, KEEP IT LOCKED UP until it realigns or the bike comes to a complete stop. You might low side (lay the bike down), but that is ALOT less painful / and less damaging than high siding.
I have to agree with you. You can practice a panic stop all you want. Your brakes can be in the best shape but you have no idea what you are going to do at the moment of truth. Instincts are instincts. I wish I had ABS.
I've experienced a front wheel lock up at a crawl speed and was amazed by how quickly my bike dropped to the ground. It was on gravel which is why it unexpectedly locked. I took quite a tumble even going slow.
I can't imagine that happening at 50 or 60 mph when in a panic to stop.
In general, the test results
demonstrated an improvement in braking
performance with the use of ABS, whether
braking on a dry or wet surface even compared
with the best stops obtained without ABS. Without ABS, the rider required numerous attempts to approach the maximum deceleration performance of the motorcycle. With the use of ABS, however, the rider was able to quickly obtain consistent maximum deceleration results, whether the vehicle was
loaded or lightly loaded. Despite this
advantage, the rider must remain alert
because the ABS may not detect dynamic
instabilities such as the rear wheel becoming
airborne, possibly requiring the operator to
reduce the brake control force to prevent a fall.
With respect to CBS, its advantage was most
evident through shorter braking distances,
specifically when braking with the rear wheel
only, whereby the CBS activates a portion of
the front brake to assist in the deceleration of
the motorcycle.
In the real world, the emergency
braking maneuver is likely to be an infrequent
occurrence. Obtaining a high level of braking
performance depends on a multitude of
variables including weather conditions, road
surface, condition and type of motorcycle
brakes and tires, and operator expertise. The
testing described above has shown that the
operation of the ABS may not be as simple as
“slamming on the brakes.” To achieve the best
braking performance, the rider must ensure
that the rear wheel is on the ground throughout
the stop.
However, the results of this testing
make it clear that, of the motorcycles tested,
those equipped with the anti-lock braking
system provide all riders with the advantage of
a high level of braking performance at the time
ABS is the best thing since wheels.I have it and love it,it is the best option by far you could have.Tell your friend to try an ABS bike in sandy or wet conditions and he'll change his tune.
I hate ABS...I believe it is dangerous. I know that it gives shorter stopping distances on a smooth test track...but I drive in the real world. On a poorly maintained road(which is becoming more and more common) if your tire is bouncing...your stopping distances are much longer.
Please show us some proof of this, or do you want us to take it on faith?
20 years ago everyone questioned ABS in cars... Now I would not want my loved ones to drive a car without it. I am confident the same will play out for bikes.
By the way last summer I had an accident on my Heritage where during a panic stop the rear wheel locked up repeatedly. I firmly believe ABS would have prevented the accident. Here is a link to the accident thread. https://www.hdforums.com/forum/gener...-accident.html
