Front end clunk fix?
Old Jan 10, 2011 | 07:52 PM
Reino's Avatar
Reino
The clunk on my softail dissapeared when the steering nut was tightened, not excessively - must still have free movement from side to side when on stand. Mine was just propably normal wear as the bikes only done 30,000km.
Old Jan 10, 2011 | 10:15 PM
oldairboater's Avatar
oldairboater
My 98 Wideglide has always had the infamous clunk. I just keep an eye on it. I have retorqued and checked fall away and rechecked.
Old Jan 11, 2011 | 12:23 AM
ackman1968's Avatar
ackman1968
Originally Posted by doublenaughtspy
Make sure the tank bolts are snug - use a wrench and tighten appropriately before you do anything else. Takes about 3 minutes, and that's if the pull tab on your beer breaks off and you have to find a can opener, and then you drop one of the sockets on the floor and kick it across the garage and it ends up under the washer/dryer..... I only have anecdotal evidence, but I'd say 90% of all people who had the clunk traced it to a loose gas tank bolt (front or rear, take your pick)
Count me in the 10% then because mine was the bearings, not the tank.
Old Jan 11, 2011 | 02:10 AM
Other Sheep's Avatar
Other Sheep
Take it apart. Repack or pack the bearings with grease and re-install the parts. The clunck will go away.
cvaria
Apr 28, 2016 03:05 PM
Road Star
Aug 3, 2014 01:28 AM
joneill
Aug 14, 2013 12:04 PM
MDStbob
Apr 26, 2012 08:13 PM
