Reinhart Tips
Old Jan 16, 2011 | 04:12 PM
kruuz2003's Avatar
kruuz2003
Stage IV
Angry Reinhart Tips
Anybody got a solution to get the Reinhart tips off? All set screws undone, soaked with penetrating oil and they won't budge.
Old Jan 16, 2011 | 04:29 PM
brunosrk's Avatar
brunosrk
This is what worked for me; took screws out then removed the tips and baffles together as one piece. used a strap wrench around the tips to get them moving. After you have the whole thing out use a rubber mallet to knock the tips off.
Old Jan 16, 2011 | 04:40 PM
kruuz2003's Avatar
kruuz2003
Stage IV
Thanks...it's very frustrating...and I didn't want to damage them if I wasn't ableto get them off. Black tips now purple...not a good look!
Old Jan 16, 2011 | 04:41 PM
HogAir's Avatar
HogAir
When I took mine off to replace the tips that had turned purple, I took it out for a ride to heat up the mufflers. As soon as I hit the garage I took out the screws and used a strap wrench to twist them out. A set of leather work gloves will also be needed for the hot tips and baffles.
That was three years ago and the replacement tips are still black...
Old Jan 16, 2011 | 04:54 PM
kruuz2003's Avatar
kruuz2003
Stage IV
Smile
Thanks ...at -20C uphere in Niagara Falls, ON it's difficult to get the pipes warm but I will run it on the jack and see if that helps. I'm a newbie on the forum and I really appreciate the responses!
Old Jan 16, 2011 | 06:20 PM
brunosrk's Avatar
brunosrk
For what it's worth . . . the method I described worked when everything was stone cold.
Old Jan 17, 2011 | 07:44 AM
Tazzrider's Avatar
Tazzrider
Not sure what kind of penetrating oil you tried, but i use PB Blaster...found in most auto stores.
I've also read that the tips turning color are due to running too lean...
Maybe someone else can verify...
Old Jan 17, 2011 | 07:49 AM
Iceman24's Avatar
Iceman24
Clean oil off exhaust before running bike - it will leave a mark...
Rubber strap, warm pipes, leather gloves & a few 4-letter words got mine loose.
GaryInDelta
Exhaust System Topics
Jul 17, 2017 08:55 PM
T Man
Jun 10, 2017 06:06 PM
Keith_71
Aug 7, 2011 11:31 PM
streetg7
General Topics/Tech Tips
Mar 22, 2011 05:01 AM
qwiktripp
May 16, 2010 02:21 PM
