Removing front reflectors
Old Oct 5, 2006 | 10:21 AM
GADave's Avatar
GADave
Default Removing front reflectors
Hey all,
Ready to remove the reflectors on the lower front forks of my bike. Checked 'em out and it appears they're just stuck on. Before I start yankin', cuttin' & pryin' on em, thought I'd ask if anyone's found an easy way to take them off quick. They're not mentioned in the service manual.
Thanks in advance for your suggestions.
Dave
Old Oct 5, 2006 | 10:25 AM
liltrk's Avatar
liltrk
Default RE: Removing front reflectors
Fishing line wrapped around two sticks. Seesaw the line behind the reflector. It will cut the tape. Goo gone to remove the residue. If they are a bit warm, it will help. Sun warm, not torch warm
Old Oct 5, 2006 | 10:35 AM
sleepneagle's Avatar
sleepneagle
OK, follow these steps.
1. Use the OL's hair dryer on high heat setting.
2. warm surfaces completely.
3. spray some WD40 on surfaces
4. mono line works great for helping to lift off.
5. clean up any residual adhesive tape using WD40.
6. wipe with clean soft cloth.
Old Oct 5, 2006 | 10:40 AM
Denbo's Avatar
Denbo
Sounds like a great idea,I'm about ready to take mine off and polish my front forks.
Old Oct 5, 2006 | 10:46 AM
rogue_rob's Avatar
rogue_rob
you can take the reflectors off??????
My dealer told me I had to purchase new forks without the reflectors!!!!!![:@][:@][:@]
Old Oct 5, 2006 | 11:11 AM
Alaska Bobber's Avatar
Alaska Bobber
ORIGINAL: rogue_rob
OMG....if you are indeed serious you need to find a new dealer.
Old Oct 5, 2006 | 11:14 AM
rkstu98's Avatar
rkstu98
Stage III
Dental Floss works great!
Old Oct 5, 2006 | 11:30 AM
sleepneagle
FDA! That's what you call a RUB Dealer. Doesn't ride, just in it for the $$$$$$$$$$$
Old Oct 5, 2006 | 01:10 PM
rogue_rob's Avatar
rogue_rob
ORIGINAL: Alaska Bobber
ORIGINAL: rogue_rob
I wasn't
Old Oct 5, 2006 | 01:29 PM
GADave's Avatar
GADave
Thanks everybody! I'll break out Mamma's hair dryer and some 20lb test Stren... sounds like a good time.
Dave
