My rubberboot came unscrewed and I lost it today. The dealer didn't have one in stock so I wait for it to arrive. Can you apply blue loctite to plastic? Thinking of ways to prevent this from happening again.
Just make sure it is screwed on too tight. I lost several last year as I did not tighten them on enough. the trick is not to over tighten them as well as the threads are plastic.
I used no loctite and it is still there now. I didn't tighten fit enough the first few times.
Just give it a twist every now and then. I wouldn't put anything on it, might migrate down to the switch and gum it up. The switch itself probably isn't waterproof.
I've used blue Loctite on all my booted switches. Never had a problem. Never had one come loose.
Here's a good one for ya. My bike is a '96 e-glide cop bike. I lost the knurl nut that holds the post. Went to the dealer and the told me the nut isn't available separately, I'd have to buy a whole new speedometer assembly. I told him I didn't need it that badly, but being I bought the bike from them they went out back to a parts bike, and robbed one off that bike for me gratis. I guess all dealers aren't out to take advantage of you.,,
Loctite blue should not be used on plastic parts.
Sometimes it causes the plastic to melt.
A very very small amount of some RTV room temp. vulcanizing compounds are good for plastic OR just some simple elmers glue (school glue).
