2004 electraglide
Old Mar 3, 2011 | 09:36 PM
crackercap's Avatar
crackercap
Originally Posted by katiedog
check the cam tensioner shoes immediately. mine were trashed at 24000 miles. switched to gear drive.
I would have to agree and suggest you check the cam tensioners, I recently checked my 04 EGC at 25000 miles and they looked good, however, there are those that failed with less miles. It requires a little work but can give you peace of mind.. enjoy your new ride, it sounds like a good deal..
Old Mar 6, 2011 | 09:30 AM
nkfd13's Avatar
nkfd13
here are some picks of new bike, not very good had to use kids camera
Attached Thumbnails 2004 electraglide-pict0035.jpg   2004 electraglide-pict0036.jpg
Old Mar 6, 2011 | 09:41 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Originally Posted by nkfd13
how do you know if the cam tensioners are worn?
You have to pull the cover and inspect them. If they are worn you will want to upgrade to the hydraulic tensioners like in the new bikes or gear drives. The hydraulic ones are about $450 for the kit and maybe $400 for labor. But do not snooze on the inspection. If you DIY the gasket is about $8. You'll have to drop the front pipe and floorboard to get at it too. Use a cheap dental mirror to loot at the inside one. If youare having this done you may also wish to upgrade the cam bearings to Torringtons while in there.
BTW, that is a sweet bike for $8500
hydrostreamracing
Oct 30, 2016 03:44 PM
ronrico21
May 1, 2015 08:47 PM
jhawk07
Aug 10, 2009 02:37 PM
Danowert
Motorcycles For Sale
Aug 29, 2008 11:42 AM
PastorTom
Aug 9, 2008 07:56 PM
