Zipper's Max flow AC
Old Mar 5, 2011 | 06:22 AM
Donefarmin's Avatar
Donefarmin
Default Zipper's Max flow AC
Has anyone installed a Zipper Max flow AC on their Ultra. I just read an article in American Iron about it, says it add up to 6 hp. I have a stock Ultra except V&H mufflers. Just checking. Thanks
Old Mar 5, 2011 | 08:24 AM
reese's Avatar
reese
Talking Worked for me
I had the Ness Big Sucker added to my 09 StreetGlide as part of the Stage 1 upgrade before I picked it up and evidently they used the stock HD air filter instead of what looks like should be a K&N style upgraded filter. I just added the Zippers kit with the ~ 5/8 inch deeper filter and my performance is better ( got the front tire off the ground in 2nd for the first time ) along with a gain in gas mileage. Previously ~32 MPG is the best I could get but on a 230 mile ride yesterday and I got 38 MPG on the first tank...
Old Mar 5, 2011 | 09:28 AM
Donefarmin's Avatar
Donefarmin
Default Thanks Reese
Thanks Reese. Thats stage 1 kit is air only right? No fuel power commander. I think I will order it. Thanks again.
Old Mar 5, 2011 | 10:19 PM
Low_Wider's Avatar
Low_Wider
I've had a MaxFlo on my '06 LR for the past two years. It was replacing the SE A/C so can't say I noticed a difference in hp. The switch was with going to a Mud modified round cover.
Old Mar 5, 2011 | 11:17 PM
SteveO-ll's Avatar
SteveO-ll
They are definitely better breathers............I happened to see a dyno being preformed the other day and witnessed an increase in power, along with better air flow readings.
I have one coming in this week and once I have my custom made pipes installed, I will be re-dynoing <sp> my bike to monitor the changes.
Old Mar 6, 2011 | 06:04 AM
reese's Avatar
reese
Stage 1 should cover Air, mufflers, SERT and Dyno. This was done at the dealer on my bike but they used the stock air filter. I just upgraded to the better air filter.
Old Mar 6, 2011 | 03:18 PM
Low_Wider's Avatar
Low_Wider
Just one other thing to be aware of is that at 5/8" deeper the A/C is going to stick out that much further. Which for me, at 5' 11" and a 30 in inseam, where the SE A/C before cleared my leg when it was on the highway bars, the MaxFlo now comfortably presses against my leg.
jdsmitty10
Apr 21, 2010 10:49 AM
Hangfire1
Exhaust System Topics
Aug 24, 2009 01:29 PM
Elbryan
Jul 13, 2009 10:45 PM
thomaskray
Nov 26, 2008 10:28 AM
dchoran
Jun 3, 2006 12:09 AM
