Security Light coming on (KEY logo)
Old Mar 12, 2011 | 01:53 PM
TORQUEY's Avatar
TORQUEY
Default Security Light coming on (KEY logo)
Any ideas? I looked online, and it seemed rather complicated, having to do with some error codes. The bike runs like a champ, starts immediately, etc. The only thing I did recently was install an LED tail light and LED signal bulbs all the way around. Then it began. Today, I installed the HD running/stop/signal switch and the light went off, but just for a few minutes, then came on again.
The manual said to take it to my HD dealer. Having some measure of experience at that particular venue, I'd rather throw my beloved baby into the sea...
Any and all help is very much appreciated.
Old Mar 13, 2011 | 06:57 AM
TORQUEY's Avatar
TORQUEY
Don't be shy now!
Old Mar 13, 2011 | 08:51 AM
TheGeek's Avatar
TheGeek
Try changing your battery in the key fob.
Old Mar 13, 2011 | 09:19 AM
handyhoward's Avatar
handyhoward
Go back and be sure that you followed all the instructions of installation of the HD LED modulator in the order that they where written... if you skip ahead or miss one step, the alarm system gets out of whack and the electrical system on the bike must be completely reset. You can do the reset, if you are willing to slow down and follow the pattern of codes one at a time in the right order.
Old Mar 13, 2011 | 11:07 AM
TORQUEY's Avatar
TORQUEY
Right you are. I did not remove either the main fuse or the negative battery terminal, for which all bikes must have one OR the other removed. However, the instructions said to do this to prevent accidental start up of the bike, so I deliberately avoided that step. The scoot was in neutral, and no way was I going to start that baby. Other than that, I followed the instructions to the "T". I wonder...
Old Mar 13, 2011 | 11:18 AM
soft 02's Avatar
soft 02
Check for a bad bulb. Mine will light up if I have a bad bulb. Do a search on how to check and clear codes.
Old Mar 13, 2011 | 03:09 PM
TORQUEY's Avatar
TORQUEY
One more observation: The key light will never appear until the first time I have to use the directionals, either right or left. Then it will stay on until the bike is shut off. When restarted, no light until...you guessed it...
Old Mar 13, 2011 | 10:52 PM
Potato_Potato's Avatar
Potato_Potato
I think you need a load equalizer. The TSM or TSSM is looking for a certain current draw and the LEDs draw much less current - that's were the equalizer comes in.
Old Mar 14, 2011 | 08:15 AM
handyhoward
I should have asked up front... which module did you install? Because tpmurray is correct you needed the module for the run,brake,turn with the built in load equalizer or an additional load equalizer to run LED turn signals.
Old Mar 14, 2011 | 08:20 AM
Bodean46's Avatar
Bodean46
+1 on load equalizer.
