carb vs. efi question
Old Mar 24, 2011 | 05:19 PM
harleydavis's Avatar
harleydavis
The Keihin CV carb is designed to perform at various altitudes without needing adjustment.........provided you have it dialed in. I live at sea level and have traveled over Tioga Pass (9,657 ft) and through the Rockies over Vail Pass (10,666 ft) with no problems with my CV carb.
As the others have said.......easy to tune, simple to fix, and can be adjusted or fixed on the side of the road. I'll be keeping this bike!
Old Mar 24, 2011 | 06:49 PM
Mr HOG's Avatar
Mr HOG
No question EFI is the way to for a touring bike. Harley's top touring bike (Ultra Classic) has been EFI standard for more than 12 years now. That should tell you something.
Old Mar 24, 2011 | 10:13 PM
Scuba10jdl's Avatar
Scuba10jdl
This. The modern CV carbs use a vacuum slide, which operates in conjunction with atmospheric pressure to regulate fuel and automatically adjusts for altitude(difference in pressure). You most likely won't hit any altitude that would mess the carb up without messing you up first.
Old Mar 24, 2011 | 10:27 PM
Bluehighways's Avatar
Bluehighways
Originally Posted by Robotech
Personal preference really.
EFI isn't hard to tune IF you understand the logic behind how all the tables work. IT IS more expensive to tune though since you can probably buy every carb jet known to man and still have about 6 $100 dinners for the cost of the program and laptop used to tune an EFI.
EFI can be push started.
EFI is very reliable. I've never had to do more than soak an injector with EFI. Biggest part of EFI that can fail is the fuel pump. Even then, I have cars with over 200K miles on them and no fuel pump issues. That technology has had the bugs worked out of it years ago. Same with the sensors in the system. Just like when a certain carb problem gives a certain kind of proplem helping you diagnose the issue, so to with a sensor failure with EFI.
Carbs are simpler for most people to work on because they are mechanical. If you have ever worked with wiring and electronics like installing a radio then EFI isn't any more difficult. For some reason wiring tends to throw people for a loop.
Really the benefits to EFI are it runs as it's tuned regardless of weather changes or engine temperatures and it's a bit more efficient. Other than that they both deliver gas to the engine.
+1 They've been using Speed/Density Port Fuel Injection since 1968 on VW's . . . I do believe that the "bugs" have been thoroughly exterminated.
If you are not good with electricity and abstract stuff that can't be seen, the visual thing about of a Carburetor can be comforting; but you'll not get the same power, fuel economy or the dependability. Short of a complete Fuel Pump, ECU or Crank Sensor failure the Harley will keep running. There are many parts in a Carburetor that if they fail will park the bike as well . . . but sometimes it feels better if the broken part can actually be seen.
Old Mar 24, 2011 | 10:39 PM
wideglidebob's Avatar
wideglidebob
man you have had both your the expert
Mikey 1450's Avatar
Mikey 1450
I prefer a carb over EFI, simple, easier and far less expensive to tune and maintain, much better "feel" at the throttle grip and I'll pick the throttle cable over that rheostat every day. Technology marches on, carbs no longer available except aftermarket... 1 day, air cooled v twins will be gone too and that will be a sad day.
Old Mar 24, 2011 | 10:51 PM
IronAss's Avatar
IronAss
Mine is carb'd and tuned for where I live. 5200 feet with fairly low humidity. I routinely go down to near sea level and up to 7500 feet and have never had any issues. Last summer I rode form Florida to Alaska across the U.S. and up the Alcan. ran in a wide variety of climates and elevations and it never missed a beat.
Don't believe all the B.S. you hear from guys that have never owned a bike with a carb. They work just fine. You might get a slight fluctuation in Idle speed at different altitudes and a miniscule loss of power at extremely high ones but not a big deal.
Old Mar 25, 2011 | 04:22 AM
Stubby3492's Avatar
Stubby3492
Originally Posted by Harley_Dude
Yes this is true, but my bone stock cv carbed evo has been to 10,000+ and didn't miss a beat.
I agree, I have the original Keihin CV carb which I rejetted and tuned. I live at sea level and I have ridden to 10-12,000 ft elevations, and I couldn't notice any difference.
Old Mar 25, 2011 | 06:10 AM
chappy99's Avatar
chappy99
carb is the only way to go,EFI is just a pain.
Old Mar 25, 2011 | 07:01 AM
tacoma5432's Avatar
tacoma5432
I feel like the carb gives a more throaty sound with a good set of pipes. Other then that i am lost. I have no mechanical background
