Stage 1 upgrade
Old Mar 27, 2011 | 04:03 PM
Seathrin's Avatar
Seathrin
Stage I
Default Stage 1 upgrade
Can anyone help with stage 1 Q"s
I bought a 2010 FLHTP with100 miles on it. After I do the dealer 1000 mile honk job, I want to do a stage 1 upgrade myself.
I'm planning on getting the V&H Dresser Dual header pipes to get rid of that F-ing CAT and then put some slip on Monster Ovals or something else for a deep throaty sound (Open for suggestions here)
Second, I need a good high flow A/C that will accomodate the stock A/C cover. Last, I have no clue about fuel mgmt....Power Commander, SERT, V&H fuel Pak????? I will be doing it myself to save on dealer dyno and labor costs...Basically, I will be broke at that point and can't have the dealer do it!
Thanks for the help!
Old Mar 27, 2011 | 04:12 PM
Superfly3176's Avatar
Superfly3176
I went with the power commander v in my sportster and love it. Makes the bike really responsive and doesn't starve it for fuel. It was also very easy to load a map from the computer and to connect it to the bike.
Old Mar 27, 2011 | 04:56 PM
johnd5412's Avatar
johnd5412
I had the fuel pak and didn't like it. I use the TTS mastertune and it is great b/c I can update my map when I make a change to the bike...lots of info on this on the forum.
Old Mar 27, 2011 | 06:01 PM
mrfikser's Avatar
mrfikser
I went to fuelmoto and they sell a SE equivalent air cleaner (actually several) several exhaust options and power controllers...I bought the se af, jackpot slipons, and PCV (pre-progammed) for well under $500 (I can't remember exactly how much...it was a great deal the bike runs great and fast...they sell a after market header that can give you few more hp if you really want it...and to top the deal off the PCV can run with 2 different maps, so I loaded in a map for power and another for fuel mileage and in stalled a toggle switch to switch back and forth (which you can do on the fly)...go check out there website. personnally if you are broke-ish I wouldn't worry about the cat. as removing it will only gain you a few hp..
Old Mar 28, 2011 | 07:13 AM
mountainpharm's Avatar
mountainpharm
Call Fuel Moto. They will set you up nicely
Old Mar 28, 2011 | 01:00 PM
nukeman19's Avatar
nukeman19
I concur with Fuelmoto. I just bought a package from Keith and couldn't be happier. I got the EFI tuner already programmed, the high flow air cleaner, and monster ovals for just over $900. It is easy to install yourself, and it makes a real difference (seat of the pants speaking). Shipping was extremely fast and free.
Old Mar 28, 2011 | 01:32 PM
dyeates's Avatar
dyeates
I just finished mine with v&h dresser dual, v&h fuelpak, Hd se a/c stage 1, and cfr muffler (used). All done for a grand! Love that sound! But research for what you want.
cruisn
Jul 17, 2019 12:08 PM
iraqivet
Jan 7, 2013 08:18 AM
super48
Apr 13, 2012 06:55 AM
Toe Knee
May 16, 2011 04:44 PM
Foodog
Mar 20, 2010 12:26 AM
