Help!!!!
Old May 12, 2011 | 06:58 PM
Ray z's Avatar
Ray z
Stage I
Default Help!!!!
I own a 2007 Sportster XLC with 2600 miles on it. Runs great on top end but in low end it hesitates, spits, and spudders until I get the rpm's up. I bought this bike with slip ons the exhaust. The bike sat for 3 years with no oil or gas change. I've drained and changed the oil and emptied the gas tank and put in 93 octane. Could you give me any suggestions?
Thanks,
Ray Zarle
Old May 12, 2011 | 07:10 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Change your plugs see if that helps. If the bike is carbed, I said IF, don't forget to push in the enrichment ****. Another thing could be the cylinder head temp sensor has failed and not allowing the cold circuit to allow the electronic fuel air mix adjust for a cold engine.
Old May 12, 2011 | 07:25 PM
Ragtop's Avatar
Ragtop
delete
Old May 12, 2011 | 07:30 PM
bwana1's Avatar
bwana1
The bike is a 2007. That means it is fuel injected. Keep the rpm up above 2400 and it will be a lot smoother.
Bwana
Old May 13, 2011 | 11:16 AM
bmorebhoy's Avatar
bmorebhoy
Check the battery. I had the same problem, same year Sporty. Had a dead cell in the battery and it would drain quickly. It would sputter at around 2000 RPM. A new battery solved the problem.
Old May 13, 2011 | 12:31 PM
jcallesano's Avatar
jcallesano
run marvins mystery oil in the tank and oil. read the directions for use. that sruff will clean the injectors and make it run healthier. I use it in my FI 06 train.
Old May 13, 2011 | 12:39 PM
Gay Rider's Avatar
Gay Rider
Hi, just so you understand WHY your sportster is running the way it is is most likely you are lugging it in too high of a gear for the speed you are traveling in the low ranges. Sportsters are meant to have a LOT of RPM's to them at all times, they are a high rev style engine and if you're under 3000 RPMs riding around town and in 3rd gear, YOU ARE WRONG!
It is designed to be ridden hard, not babied, it's a Sportster, it can take it I promise you that!:-)
ahok19
Mar 8, 2015 04:33 PM
Sporty666
Oct 23, 2013 06:36 PM
davemandu
Jun 17, 2013 03:09 PM
maduxfn31
Jun 9, 2013 12:53 PM
chamba
Nov 2, 2011 11:35 PM
