Tire Replacement?
Old May 28, 2011 | 12:11 AM
garand's Avatar
garand
Plug it.
Old May 28, 2011 | 04:27 AM
Jrsess's Avatar
Jrsess
Pull the screw out . If it leaks patch it. If it doesn't leak your good to go.
Old May 28, 2011 | 05:16 AM
Ratster's Avatar
Ratster
Originally Posted by lo-rider
Don't screw around. Replace it.
Originally Posted by rickb
Plug it if not on the side wall. Keep riding.
DOH!!!
Old May 28, 2011 | 05:22 AM
cdestuck's Avatar
cdestuck
999 out of 1000 times you would be ok in patching and the truth be told, I'd might do the same thing also. Just one of the reasons I picked up the tire and wheel coverage lately.
Old May 28, 2011 | 06:34 AM
ttboy's Avatar
ttboy
Just had my rear let go at 80mph 2up with the OL. Tried to patch but too big a hole. The Stealer was kind enough to replace with a new Dunlop for a mere $353 out the door. He did wash it too.
Old May 28, 2011 | 06:46 AM
Rickl's Avatar
Rickl
Path/plugging a tire on a cage affects 25% of the rubber on the ground, on a bike 50%. Well, are you feeling lucky punk . . . well, are you?
Old May 28, 2011 | 07:16 AM
Phrogman's Avatar
Phrogman
Patching/plugging a tire is one of those things, you're going to get some people who swear that you shouldn't and some that swear that you should.
I have patched tires and had no problem and I have patched tires and had problems, it's not a guaranteed thing. Because of that, some people feel you should always replace a tire instead of patching but the truth be told, there's risk even with a brand new tire. Not as much as with a patch, but even new tires fail on occassion and get blowouts.
Old May 28, 2011 | 02:18 PM
Sikk50's Avatar
Sikk50
Thank you everyone, I guess I'll replace it. Patching makes me some what nervous I think. It's a pretty big screw and really my only fear of riding is losing a tire around a corner or on the freeway
Old May 28, 2011 | 03:43 PM
MisterPX's Avatar
MisterPX
It's almost been 24 hours, if it hasn;t leaked yet, the nail/screw may not have penetrated far enough. Pull that sucker out and see.
Old May 28, 2011 | 08:16 PM
txfxstrider's Avatar
txfxstrider
+1.
Often a nail or screw does not penetrate far enough to cause damage to the tire. If it does leak, patching or replacing is up to you. I would replace.
