Tube question
Old Jun 6, 2011 | 01:28 AM
Cowpokey's Avatar
Cowpokey
I reused the tube in my back tire, cause the one I bought wasn't the right size. Seams ok so far. I'm going to change wheels next winter and will going tubeless.
Old Jun 6, 2011 | 01:32 AM
txfxstrider's Avatar
txfxstrider
That's a good question. Probably not necessary but I have never known a dealer that did not replace them when replacing a tire.
Is replacing a valve stem necessary when replacing a tubeless tire? Same answer.
Old Jun 6, 2011 | 08:33 AM
carlgrover's Avatar
carlgrover
Always replace the tube when replacing the tire. It's a good idea to replace the rim strip as well.
Old Jun 6, 2011 | 09:22 AM
Griff012FLHX's Avatar
Griff012FLHX
Yes....
I'll be changing tires on wendsday....
Tubes and strips as well.
I read on here that you can get special spokes that allow you to run tubless....
Old Jun 6, 2011 | 11:04 AM
oct1949's Avatar
oct1949
Bout all dealer will, but last yr I did the front and rear, our Indy checked them and will reuse them one time if they check out ok.. Need new rear again so I'll probably ask for a new one this time.
Old Jun 6, 2011 | 12:57 PM
tealdreams's Avatar
tealdreams
I had a tubeless spoked rim on my 2001 roadking classic on the rear, it sucked every 3 weeks I was putting air in it.I changed back to a stock for a while and then I had problems with the spokes so I put a stock rim off a roadking standard because you really cant see it with the bags on.No more problems.
JerryDinMD
Jul 4, 2014 11:56 AM
steelpix
Jun 8, 2014 09:34 AM
shaneK
Dec 5, 2013 10:39 PM
sparky_mo
Mar 14, 2009 07:45 AM
'05Train
Oct 18, 2008 07:25 AM
