Winter Storage
Old Nov 4, 2006 | 12:52 AM
RKR97's Avatar
RKR97
Default Winter Storage
Ok with all the diffrent ideas about storing bike, I thought it would be a good idea to share what you do when putting your bike away for the winter months.
I keep it simple just in case I need to pull it out and ride it cold or not.
I fill the tank full of fuel. Put it up on the jack. Put the battery tender on it and cover it up.
Your turn!
Old Nov 4, 2006 | 01:20 AM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Default RE: Winter Storage
that is prolly good enough, but fuel stabalizer won't hurt, but if run once a monthg and tank refilled prolly not needed
Old Nov 4, 2006 | 01:41 AM
natewat's Avatar
natewat
This probably a dumb question but why is the jack necessary?
Old Nov 4, 2006 | 01:43 AM
millzog's Avatar
millzog
So you don`t get flat spots on the tires from sitting in one place too long.
Old Nov 4, 2006 | 01:44 AM
RKR97's Avatar
RKR97
I use the jack just to keep the weight off the susspenssion and off the tires. We acctually do it every week with the race car also. It's just to keep shocks and things from wearing out premautrely
Old Nov 4, 2006 | 01:45 AM
Jovimon's Avatar
Jovimon
I fill the gas tank and then ride it a couple of hundred miles a week to keep the battery charged.
Old Nov 4, 2006 | 01:47 AM
natewat's Avatar
natewat
Ok, adding a jack to the list.
Old Nov 4, 2006 | 01:49 AM
02deucerg's Avatar
02deucerg
No fluid change?Any oil(crank case) with more than about 500 miles has the potential to do some damage if it sits to long.
Old Nov 4, 2006 | 01:50 AM
RKR97's Avatar
RKR97
Normaly I would but I had that done less than 100 Miles ago so I skiped it this year.
Old Nov 4, 2006 | 02:21 AM
Nadil's Avatar
Nadil
What is winter storage???
