DIY cam job. paper clip revision.
Old Jul 5, 2011 | 10:50 PM
soft 02's Avatar
soft 02
Default DIY cam job. paper clip revision.
So some say they use the binder clip trick holding the lifters and it works great others had no luck. I though that being a mechanic I wouldn't have any trouble. I ground the tips and all but there wasn't enough lip to grab the lifters. So what I did was to bend the tips almost straight and insert them into the oil hole in the center of the lifters and then it worked great. Hope that helps someone else and prevents them from buying a tool that only gets used once.
Old Jul 6, 2011 | 03:11 AM
ElectraDave's Avatar
ElectraDave
will keep this one in mind as i plan to do a cam swap in the near future. thanks soft 02.
Old Jul 6, 2011 | 05:44 AM
blair's Avatar
blair
been using the paper clip on the lifters for years and your right it works great !!!
Old Jul 6, 2011 | 06:41 AM
Notgrownup's Avatar
Notgrownup
I also just bent the tips and ground them to a sharp edge and worked fine...First time doing it too...
psoff
Milwaukee Eight (M8)
Aug 25, 2018 03:44 PM
Daredevil
Mar 30, 2017 01:07 PM
Kees
EVO
90
Dec 7, 2013 01:32 AM
Noble Steed
Exhaust System Topics
Feb 28, 2008 07:15 PM
Brooklyn Redneck
Mar 23, 2007 10:40 AM
