Programming a Personal Code
Old Nov 7, 2006 | 04:51 PM
aframe2's Avatar
aframe2
Default Programming a Personal Code
Has anyone successfully programmed a 5 digit personal code using the left and right turn signal switches as described in the owners manual? I have an 06 Road King and have never programmed a personal code. I decided to finally program a code and of course it doesn't work for me. All I get is the hazards blinking. If someone could walk me through the procedure I would greatly appreciate it. Thanks
Old Nov 7, 2006 | 04:53 PM
harleyxlc's Avatar
harleyxlc
Default RE: Programming a Personal Code
I programmed mine and didn't remember any issues, be sure to hold them down long enough to start the process.
If no one else chimes in, I can go through it when I get home from work
Old Nov 7, 2006 | 05:17 PM
pjweber's Avatar
pjweber
Mine workd as described in the owners manual. It took me a few time through, it took a little pratice.
Old Nov 7, 2006 | 10:09 PM
harleyxlc's Avatar
harleyxlc
Checked my book and it still works....for mine anyway....
Ignition, off, ignition, off, ignition wiht the key fob
Press the left turn signal 3 times (quickly and quickly after you do the ignition)
Press right turn signal once (again quickly)
Turn signals will flash and display the current pin.
Use left to cycle through numbers and right to enter each digit.
Turn ignition off as soon as you are done.
Old Nov 7, 2006 | 11:12 PM
firemankrug's Avatar
firemankrug
Ditto for me, I did notice that I had to make sure I pushed the turn signals all the way in.
Old Nov 7, 2006 | 11:14 PM
dastark's Avatar
dastark
Tried it when I first got the bike unsucessfully. But I had a buzz on. Haven't tried since.
Old Nov 8, 2006 | 12:07 AM
RKGary's Avatar
RKGary
I programed mine with little problems. I did have my son read the instructions while I programed it. I liked the odometer showing the code as I programed it.
Old Nov 8, 2006 | 12:16 AM
ironhorse's Avatar
ironhorse
Seems like it should be easier for us.
Iron Horse
Old Nov 8, 2006 | 01:17 AM
MAX EVO's Avatar
MAX EVO
What is a personal code?
Old Nov 8, 2006 | 03:59 AM
Thirdup's Avatar
Thirdup
ORIGINAL: MAX EVO
A code programed into your bike which can them be used to bypass the security system should you lose your key fob.
As to the OP, I programed mine in the other day with no problems.
