Programming a Personal Code
Old Nov 8, 2006 | 04:55 AM
Monzie's Avatar
Monzie
Default RE: Programming a Personal Code
ORIGINAL: harleyxlc
Checked my book and it still works....for mine anyway....
Ignition, off, ignition, off, ignition wiht the key fob
Press the left turn signal 3 times (quickly and quickly after you do the ignition)
Press right turn signal once (again quickly)
Turn signals will flash and display the current pin.
Use left to cycle through numbers and right to enter each digit.
Turn ignition off as soon as you are done.
I have been having issues as well. After checking your directions with my 05 sporty book my book never says anything about using the right sig to set the code. Runs off to try again...
Old Nov 8, 2006 | 05:30 AM
Monzie's Avatar
Monzie
It seems as the system changes from year to year or for different bikes I went through the procedure in my manual again and got it to work. Remember if the book says quickly it means really fast, I think this is where I was having problems.
Old Nov 8, 2006 | 06:20 AM
aframe2's Avatar
aframe2
Thanks guys for all of the advice. I tried everything that you said to do, went back to the book and still can't get that thing to work. I guess I'll go to the dealer and see if they can help. Thanks again.
Old Nov 8, 2006 | 03:20 PM
xmeter's Avatar
xmeter
You are not kidding about the 'Really Fast'. Took me a few tries before I finally got it.
Old Nov 8, 2006 | 06:31 PM
softail2005's Avatar
softail2005
Thanks for the post, I have not changed my code from the one that is in the bike from the factory. Not smart on my part. I will give it a try one cold winter night when I am bored to death and connot ride.
Old Nov 8, 2006 | 06:34 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
I have successfully programmed a personal code in both my 03 Heritage and 06 Ultra.
Be sure to clear a battery disconnect prior to beginning the programming.
Now if I could only figure out the difference between high sensitivity and low sensitivity.
Old Nov 8, 2006 | 06:50 PM
aframe2's Avatar
aframe2
ORIGINAL: softail2005
Softail, make sure you are really bored, because ever since I first posted on this subject I've been trying to program my code; and its so messed up now I may have to trailor my bike to the dealer. It just doesn't work for me the way the instructions say it is suppose to work. Good luck!
Old Nov 8, 2006 | 09:38 PM
DenimStreet's Avatar
DenimStreet
Didn't know about that, will have to try it.
'10 Wide Glide
Jul 11, 2018 09:49 AM
DevaRoh
Jun 26, 2014 01:44 PM
markkoby
Nov 5, 2012 11:13 PM
Dynalmadman
Aug 28, 2012 08:02 PM
0Nightster7
Jun 28, 2010 07:32 AM
