'11 FBLo. Setting security alarm code.
Old Aug 27, 2012 | 04:14 PM
Dynalmadman's Avatar
Dynalmadman
Default '11 FBLo. Setting security alarm code.
Okay, I guess I am not as sharp as I thought. Did searches and found out how to set the alarm code. My bike came without the owners manual, so I am doing this from web info.
I have the hands free fobs, 2 of them. I have it on the speedo when trying this.
I tried with both the kill switch set to run, and off.
I take ignition to ign-off-ign-off-ign
Then press left turn signal 3 times
Press right turn signal 1 time.
Nothing displays, right turn signal continues to blink. Read somewhere else that you press left signal only 2 times. This didn't work either.
I read you have to do all the actions in less than 2 seconds, I tried to do it both ways as quickly as I could, no go.
Am I missing something obvious? This should not be this hard. Like I said, I did a search and read the directions, just can't make it work.
Thanks
Michael
Old Aug 27, 2012 | 04:47 PM
Reaper 9's Avatar
Reaper 9
Wink Entering your PIN Number!
LOL,
I know what you mean. I just had mine installed and it took me a bit to figer it out( and that was with the manual!! Here you go.
Turn ignition on and immediately hold both turn switches in until 5 dashes appear in the odometer window. Enter the first code by pressing the LEFT turn switch. Press the RIGHT turn switch one time. Enter the second digit code by pressing the LEFT turn switch.Then just keep going back and forth!! The right moves it to the next space to put the code in the Left enters the code. Hope this helps!
Old Aug 27, 2012 | 04:59 PM
Dynalmadman
Reaper 9
Thanks, but I think that is the procedure to disable the alarm after you setup the code the first time.
I am trying to get to the setup to just enter my own code.
Cannot get it to work.
Thanks
Michael
Old Aug 28, 2012 | 08:57 AM
Reaper 9's Avatar
Reaper 9
Your right I miss read your post!! I'm not sure but let me ask around for ya!
Old Aug 28, 2012 | 09:03 AM
Reaper 9's Avatar
Reaper 9
I found this see if this works for ya.
http://www.ehow.com/how_5632825_set-alarm-harley.html
Old Aug 28, 2012 | 04:11 PM
BARACU's Avatar
BARACU
Big Kahuna HDF Member
Here's the instructions for my 2012. Should be the same
Off/Run switch to.... OFF
Ign switch to... IGN
Off/Run switch....RUN - OFF -RUN - OFF- RUN
Press left turn.... 2X
Press right turn ...1X
Enter 1st digit of new PIN by pressing and releasing left turn signal til number appears
Press rt turn signal 1 time and release
Continue thru all digits
Turn Off/Run switch to OFF....then turn IGN to OFF
Old Aug 28, 2012 | 07:19 PM
Dynalmadman
BARACU
Genius. That was it. It took cycling the kill switch on and off, not the ignition switch.
Thank you very much.
Michael
Old Aug 28, 2012 | 08:02 PM
BARACU's Avatar
BARACU
Originally Posted by Dynalmadman
BARACU
Michael
Glad to help.
Hero
Sep 13, 2023 02:15 PM
'10 Wide Glide
Jul 11, 2018 09:49 AM
dustin1014
Jan 4, 2014 03:09 AM
rowle
Feb 24, 2013 01:45 PM
0Nightster7
Jun 28, 2010 07:32 AM
