Is it true that Harley's are equipped with a Heat Management System, that will shut off the engine when it is running to hot? I spoke to my Stealership yesterday, and they attributed a problem that I had with my bike as a "sensor" chip that shut down the bike. I never heard of this before.
I've only had one of my Harleys go into full blown heat management before I knew what it was. Freaked me out as I thought it was going to seize. When the engine reaches a high enough temp, it actually cuts the firing alternatively from the plugs so you have a misfire feeling. It's all good though, the system is just allowing the air and fuel to cool the top end down. As soon as you gas it to pull away, everything's firing again.
