White Wall tire paint.
Old Aug 3, 2011 | 01:15 AM
dogman989's Avatar
dogman989
2nd Gear
Default White Wall tire paint.
Anybody use this before? Saw some of this on ebay for $30. Simply says you do your own painting on the tires, doesnt crack, or have color bleed through.
thanks.
Old Aug 3, 2011 | 07:32 AM
piasspj's Avatar
piasspj
Not sure which paint you are looking at. I have bought tire markers at auto parts stores to touch up letters or white walls. A lot cheaper than $30.
Old Aug 3, 2011 | 07:43 AM
WS6 Formula's Avatar
WS6 Formula
The below may be a better option:
Originally Posted by WS6 Formula
Port-O-Walls for Bikes: http://www.mooneyesusa.com/shop/prod...oducts_id=1694
(PRICE IS FOR EACH)
Prices start as low as 10.00 per wall!
A quantity of 2 would be needed for each tire. This makes replacements easy and as needed.
An affordable and simple alternative to full-priced white wall tires are these Port-O-Walls, also known as White-Ribbons or Whitewall Toppers. Made completely of durable soft rubber, this simple addition drastically changes the appearance of your ride. Easy to mount, no special skills or tools needed.
They are held in by place by air pressure from the tire and the bead of the rim. The inside edge of the Port-O-Wall is pressed on the lip of the rim causing it to lay on the tire.
Available in many sizes and widths.
Customize your ride today!
The following are for motorcycle
WW1408MCEA > 8" . . . ....... . $10.00 each
WW1410MCEA > 10" . . ....... . . 12.50 each
WW1412MCEA > 12" . . ....... . . 14.00 each
WW1413MCEA > 13" . . . ........ . 14.00 each
WW1416MCEA > 16" . . .......... . 14.00 each
WW1417MCEA > 17" . . . . ........ 15.00 each
WW1418MCEA > 18" x 2" . . . . . 15.00 each
WW1418SMCEA > 18" x 7/8" . . . 15.00 each
WW1419MCEA > 19" . . . ......... . 16.00 each
http://www.youtube.com/watch?v=jNit3...layer_embedded
stormcooker
The General Motorcycle Forum
Apr 10, 2012 01:31 AM
oakleaf
Apr 1, 2011 05:52 PM
duluth
Wheels/Tires
15
Feb 27, 2011 12:25 AM
nwhooligan
Oct 14, 2009 04:16 PM
bdavis
Ironhead
Aug 30, 2007 07:46 AM
