Recommend a good torque wrench?
Old Aug 3, 2011 | 11:38 AM
jukkinator's Avatar
jukkinator
Default Recommend a good torque wrench?
Have two from Sears, the click type, one 1/2" & one 3/8" drive.
Noticed when checking critical fasteners on allen heads, that it seems like i'm over-torquing, that is it never clicks...kind of like the soft allen socket is "torquing".
Also noticed that it is hard to find one wrench with a wide enuff range to hit all fasteners.
Anyone recommend one of those dial types that i saw...like in the youtube video of the guy changing cams.
I dont mind paying for a good tool
thanks
Old Aug 3, 2011 | 11:44 AM
Sam E.'s Avatar
Sam E.
Wow, that turned out much larger than expected. This torque wrench is about as good as they get.
Old Aug 3, 2011 | 11:45 AM
dyna rider's Avatar
dyna rider
Default Torque Wrenches
You really need one of each size drive i.e. 1/4"-3/8"-1/2" to cover all the bases.Those things with the dial or just a scale, I call torque meters. They are just as accurate as a click type wrench but you have to eye ball the scale or dial to get the proper torque. Sounds like yours just needs to be calibrated. Supposed to be every 2 years.
Old Aug 3, 2011 | 11:49 AM
aces25's Avatar
aces25
If you want to pay for a quality tool, you can't go wrong with Snap-on.
Craftsman typically has lifetime warranty on hand tools... maybe you can get them replaced?
Old Aug 3, 2011 | 12:03 PM
Lyfer's Avatar
Lyfer
That's what I use too. Ft and In lbs
Old Aug 3, 2011 | 01:56 PM
webbdog8's Avatar
webbdog8
if you are looking for a life time warranty the craftsman only has a 1 year warranty in the torque wrench
Old Aug 3, 2011 | 02:05 PM
petemac's Avatar
petemac
I use Craftsman and never had a problem with them. Can't see dropping the $$ on Snap-on for occasional weekend use.
Old Aug 3, 2011 | 02:17 PM
wraplock's Avatar
wraplock
I have the craftsman wrench and have always found it to be right on. It gets used a lot when I'm doing motor work on my classic cars. I was told to apply a little oil to the threads of the fastener before using the wrench for accuracy. And most motorheads don't reuse critical fasteners after they have been torqued, there is a stretching factor involved. As far as the allen head sockets, I use them here in my machine shop for tool and die work and have seen many twist under extreme use. This may be why your wrench isn't clicking.
Old Aug 3, 2011 | 03:02 PM
aces25's Avatar
aces25
Interesting. I bought a click-type torque wrench from Northern Tool with a lifetime warranty. So far so good.
Old Aug 3, 2011 | 03:25 PM
mike06train's Avatar
mike06train
I have 2 craftsman's and a snap on. Just broke the head on my snap-on after 24 years. The craftsman's don't seem to hold up. But I use them alot. Try getting them calibrated.
