starting problems !
Old Aug 26, 2011 | 10:46 PM
Jessie's Avatar
Jessie
Question starting problems !
Hello My friends I was wondering if you could give me your oppinion I have a 07 FXDC and a couple of years ago I put on a pc III usb and it used to start instantley but over the last couple of months it seems to be draging it escalated to where U press start and it cranks 4 times and I stop and press again 4 more revs and after pressing a 3rd time and 4 cranks she would fire up I put a new battery 5/1/11 a USG UBVT-1 and so I took it back and got a replacement today and after charging it started after 4 cranks but on first push of starter so is this normal or is there somthing else going on here I only have 12,000 miles on her and I also downloaded the updates for the power commander but when I first put in the new battery she wouldnt start so I had to (charged for half hour ) charge for a couple of hours b/4 she would start ! any oppinion would be greatly appreciated ! JT
Old Aug 27, 2011 | 12:22 AM
Other Sheep's Avatar
Other Sheep
New plugs might help. Inexpensive to do.
Old Aug 27, 2011 | 01:45 PM
nevil's Avatar
nevil
Check your battery cables, especially the negative one where it grounds to the bike. You also might have hole in your in tank fuel line. When you turn on the ignition you can hear the pump prime, but if there's not a full tank you can also hear if you have a leak if it sprays the inside of the tank.
Old Aug 27, 2011 | 02:10 PM
chamokie's Avatar
chamokie
I would give it a shot of start fluid, if it fires up right away your issue is fuel, not really up to date on computer controlled engines, but what ever replaces the accelerator pump may be not doing its thing. If it does not fire right up, then you have an ignition issue to deal with.
Old Aug 27, 2011 | 04:02 PM
Araba Shriner's Avatar
Araba Shriner
+1 on new plugs
tmultra
Apr 17, 2018 09:42 AM
rs1250xl
Sep 21, 2016 03:49 PM
Wranglin4Life
Jun 13, 2016 12:39 AM
BuzzL
Nov 25, 2015 10:14 PM
mjrobinson
Sep 23, 2011 06:34 AM
