seating pistons
Old Nov 19, 2006 | 02:32 PM
1sportytrike's Avatar
1sportytrike
Default seating pistons
I found out that my trike had a blown head gasket. Not trusting myself to do the job I took it it to a good cycle shop. While fixing that problem he found that whoever put the 1200 kit in it (way before it was mine) screwed up the job and somehow put the wrist pins clips in wrong. He showed me the pistons and I could see the damage to the wrist pin hole. Luckily no metal had gotten into the cylinder but I think that in a real short time I would have had major problems. I decided to go ahead and put new Keith Black pistons and rings in to make sure the problem was solved. Now I need some advice on how I should ride to make sure the pistons are seated right. The mechanic said to just ride normally but not to open it up for a few hundred miles. I've looked on the internet for other advice but it seems that everybody has a different opinion. Any members got a tried and true method?
Old Nov 19, 2006 | 02:55 PM
whaap's Avatar
whaap
Default RE: seating pistons
Yeah, you will find some guys here that subscribe to "ride it like you stole it from mile one". I don't know that they're wrong as I've never tried it but I do know riding the first 500 miles just as if it was a new bike (not over 50 mph, vary speed, etc.) has never failed me yet and that is what I would do.
Old Nov 19, 2006 | 03:14 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
it's pretty much like a new bike/new motor break in, go easy for 500 miles, vary hte RPMs, no wide open for a more than a few seconds etc
Old Nov 19, 2006 | 03:15 PM
bobcowan's Avatar
bobcowan
Ideally, you want a lot of mild acceleration and decelaration under closed throttle. Lots of gentle miles with varying speed, but get the rpm's up to about 3K'ish quite a few times. Multiple short trips with lots of heat/cool cycles. That's about it. Not rocket science. With todays materials, it doesn't take much.
Sportrider79
Apr 21, 2012 08:26 PM
Mike in Oregon
Apr 29, 2011 01:30 PM
osb
Apr 5, 2010 08:07 AM
drtheo
Exhaust System Topics
24
Jan 19, 2009 08:02 PM
Windup08
Sep 27, 2007 02:11 PM
