primary chain help
Old Sep 23, 2011 | 06:46 AM
JohnnyC's Avatar
JohnnyC
So it's over-stretched to the max.
I never know how much a poster knows about what they are doing. So you did already know about the adjuster.
The puller I used for my bike was a steering wheel / harmonic balancer style, but I believe your clutch assembly is a bit different and may require a different style. Once you load it (put tension on it) taping the pullers center shaft with a hammer will typically break it loose.
I have seen a variety of pullers at auto stores that might work.
Have you loosened the compensator bolt yet? I use an electric impact to brake mine loose
Old Sep 23, 2011 | 07:15 PM
xMPRx's Avatar
xMPRx
yes the adjuster is maxed out. and no i have not adjusted the compensator bolt yet. im waiting for manual to arrive and wasn't sure if it was left handed or right handed threads
Old Sep 24, 2011 | 09:06 AM
JohnnyC's Avatar
JohnnyC
Compensator is threaded the standard direction and can be a problem to break loose as it and the hub are secured with loctite. The clutch hub nut is reverse, or left hand threads.
StreetGlide515
Feb 20, 2015 06:58 AM
IndianHarley
Welcome Area Only
11
Oct 16, 2014 08:09 PM
OneBlackFly
Sep 13, 2007 12:48 AM
cwsharp
Exhaust System Topics
Aug 13, 2006 10:30 AM
Johneb48
Aug 9, 2006 01:14 AM
