primary chain help
Old Sep 21, 2011 | 11:59 PM
xMPRx's Avatar
xMPRx
Default primary chain help
hey guys new to forum. i have an 89 fsxt and i wanted to replace the primary chain. after tacking off the primary cover and getting down to the left handed thred bolt> i still cant get the clutch to slide off. i have the snap ring off even striped down and took all the clutch plates off thinking it would come loose but it wont budge. please help
Old Sep 22, 2011 | 06:21 AM
carlgrover's Avatar
carlgrover
Repost your question in the "EVO classic models" section of this forum. You'll have your answer quickly. Lots of good help down there.
Welcome to the forum.
Old Sep 22, 2011 | 07:08 AM
JohnnyC's Avatar
JohnnyC
You don't have to run to EVO forum and post. Most first time posters do stop over to the new member forum for their first posting. This thread probably will get moved but it is best to pick a specific forum for specific questions. If your in the right forum chances are others will know what you are talking about and will have experience on just what it is you need.
The clutch drum is keyed to the mainshaft and always requires a proper puller to break it free.
I'd strongly recommend getting the service manual before removing a single bolt off the bike. Dis-assembly and reassembly info is VERY important, along with correct torque ratings for every single bolt on the bike.
Old Sep 22, 2011 | 07:13 AM
BassCatcher's Avatar
BassCatcher
Yeah, all of that. Welcome to the forum.
Old Sep 22, 2011 | 10:46 AM
hatchetman's Avatar
hatchetman
Ya dude, you need a puller to get it off. When you re install, put some loc tite on your key way to hold it in place while you slude the basket back on the shaft!
Hatch.
Old Sep 22, 2011 | 08:36 PM
xMPRx's Avatar
xMPRx
ok thanks for the info guys. and the heads up on posting in the right section. so i need a puller? is that a specific Harley tool or universal? and im just trying to replace the primary chain is there another way?
Old Sep 22, 2011 | 09:18 PM
JohnnyC's Avatar
JohnnyC
What's wrong with the chain that's on it?
Old Sep 22, 2011 | 09:35 PM
xMPRx's Avatar
xMPRx
the old chain is stretched out> i have the adjustment up all the way and its still banging like hell on the primary case
Old Sep 22, 2011 | 09:42 PM
TennesseeMustangPerf's Avatar
Yup, you will need a jaw type puller.
Old Sep 22, 2011 | 10:42 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Check my recent post on how not to do it. Newer bike just pull off by hand. Yours is different and you need to be careful. Be sure to post back here on the detail.
And also welcome from Virginia....
https://www.hdforums.com/forum/gener...get-to-it.html
