Let's see your non-stock rear pulleys!
Old Oct 29, 2011 | 12:34 PM
BlockHead96's Avatar
BlockHead96
Originally Posted by WS6 Formula
Fill me in on the shock set up, what bike are those off of and what was involved.I don't like my stock set up, I leave them on #2 setting because of my back problems, but I get to much PoGo out of them in the turns. If I turn them up, I'm sure I'll feel the road even more, which will transfer to my back. This thing feels every pebble on the road as it is..
Old Oct 29, 2011 | 01:24 PM
WS6 Formula's Avatar
WS6 Formula
2007 Street Glide Air Shocks P/N 54631-02B, info below:
Here's some more information on the air shocks below. The chrome shocks that I ordered above in my previous post had a couple of problems.
One problem is mentioned above. I used individual Schrader valves, which brought my attention to another problem, one of the shocks will not take any air, almost seems like the port in the head of the shock was not drilled all the way through.
So if your using the Harley set up with the single Schrader valve splitting off to both shocks, chances are you wouldn't notice the decreased air capacity of one shock not taken any air.
Recommended air pressures
0-10 lbs for a 150-lb to 200-lb rider.
5-15 lbs for a 200-lb to 250-lb rider.
20-25 lbs for a rider with passenger.
FL air preload rear suspension range is 0-35 lbs of pressure.
FLHRS and FLXH low-profile shocks are 0-50 lbs max.
Harley Davidson, air valve, and hose set up
(One Schrader valve that splits off to both shocks)
54536-02A air shock valve / hose
54320-97 push-in hose fittings (order two, one for each shock)
Individual Schrader Valves
Milton Industries (MILS684) Tank Air Valve
http://www.tooltopia.com/milton-s684.aspx
NAPA part # NTH 90294 (90-294)
http://napaonline.com/Search/Detail....294_0006476757
NAPA part # NTH 90290 (90-290)
http://napaonline.com/Search/Detail....290_0215254349
I did the same but used the shorter Street Glide shocks. Much smoother ride, really takes out the road chop. I use a air compressor with a regulator set at 40 psi to fill them, then use a pressure gauge with a bleed off valve and bleed them down to 10 psi. Only modification to make them fit is to trim the rubber boot where it attaches to the shock so that it doesn't interfere with the belt guard, might be better just to shim the shocks out about a 1/4".
More info here: https://www.hdforums.com/forum/showt...eferrerid=9012
Old Dec 12, 2011 | 10:34 PM
BlockHead96
Any idea if P/N 54635-09 will work??? Then another question would be, will they clear saddle bags??
Also, did they alter ride height?
Old Dec 29, 2011 | 04:52 PM
BlockHead96
I put this valve on the shock, is there any way to prevent oil from coming out when you remove the air chuck or tire gauge? Is there some other specialty valve? How does the HD ones work without letting oil out?
Old Dec 29, 2011 | 05:12 PM
Tom84FXST's Avatar
Tom84FXST
Old Dec 31, 2011 | 08:09 AM
TORQUEY's Avatar
TORQUEY
Cool looking Sprotor!
Old Dec 31, 2011 | 04:08 PM
kiwideuce's Avatar
kiwideuce
here's my billet one,got it really cheap of ebay brand new
Old Dec 31, 2011 | 04:10 PM
kiwideuce's Avatar
kiwideuce
Originally Posted by Tom84FXST
what sort of fender are you running?
Old Dec 31, 2011 | 04:12 PM
TORQUEY's Avatar
TORQUEY
Looks cool!
Old Dec 31, 2011 | 04:17 PM
funnythebunny's Avatar
funnythebunny
I traded her for the SG, but at the time, I had a chromed true spoked pulley... Wish I still had that pulley, 'cause I don't know where I got it from... it was expensive, that I DO remember
