Winter storage question.
Old Nov 8, 2011 | 04:23 PM
sandpacker's Avatar
sandpacker
Default Winter storage question.
I see several threads going on winter bike storage. None of them address protecting the chrome ect I plan on storing my Wideglide in a closed up unheated building and cranking it at least once a MONTH DURING THE WINTER to keep the batt up ect. My question is should I use a cover on it even though its inside? Should I wipe down the chrome any? Or will it be fine uncovered in the cold all winter? Does anyone use Sta-Bil gas treatment during storage?
I know the cold draws mosture. And yes I plan on changing the oil when it gets warm again.
Old Nov 8, 2011 | 04:29 PM
fxd03's Avatar
fxd03
I keep mine in a unheated garage I just polish up the chrome put Sta-Bil in the tank and run it for a while and put a tender on the battery my chrome still looks good and have the battery that came with my bike in 03
Old Nov 8, 2011 | 04:32 PM
DannyZ71's Avatar
DannyZ71
Where in the "South" do you live? Starting it once a month and not riding it could be bad for it. You need to get it out and ride it if you're going to start it. A battery tender will do a better job of keeping the battery in good shape, IF you're not going to ride it at all. Protecting any of the metal is best done with a good wax job. Cover it if you want. But remember, even covering it with a sheet can be a bad deal if moisture gets into the garage. Covering it with a cloth that gets damp will only keep the dampness against the bike for a longer period.
Old Nov 8, 2011 | 05:27 PM
piasspj's Avatar
piasspj
I'll park mine in an unheated garage, fresh oil change (all 3 holes), a full tank of gas treated with stabil, a battery tender plugged in and loosely covered with an old bed sheet. During the winter I'll spend some time cleaning, polishing, maybe get some new accessories and generally checking things over.
On nice days I will even take a ride, top off the fuel tank after every ride). Been doing it this way for years (except I used to use a regular battery charger about once a month).
But that's all still a few weeks away, more I hope.
Old Nov 8, 2011 | 05:56 PM
crackercap's Avatar
crackercap
I put my bike in a wheel chock(to keep straight up, uses less room) usually a full tank of gas with sta bil or seafoam, I use a harley cover, battery tender hooked up, and wait till the next available riding day. I change fluids only when next scheduled. Bike is kept is an unheated garage along with cars, etc. My 2cts......
Old Nov 8, 2011 | 07:45 PM
Scuba10jdl's Avatar
Scuba10jdl
Please, please, please, do not do this. It will lower your battery charge (never gets run at high enough RPM long enough to recharge the power lost in starting/idle), and you will build up water condensation that doesn't get burned off. That means water in your pipes, engine, tranny, etc.
Only start it if you plan on riding it until it is at operating temp and for a fair amount of time.
Old Nov 8, 2011 | 08:07 PM
Karnevil's Avatar
Karnevil
just ride it! wash as normal
Old Nov 8, 2011 | 08:08 PM
PistonPuller's Avatar
PistonPuller
All you need to do is fill the tank and hook up a battery tender. Dont start it and let it idle. You are better off with the tender.
Old Nov 8, 2011 | 09:12 PM
sandpacker's Avatar
sandpacker
Thanks guys . You answered my questions. After reading and reshearching I think . I will avoid cranking it unless im gona ride.
Now I just got to get me a Batt tender.
Old Nov 8, 2011 | 09:28 PM
Night Crawler's Avatar
Night Crawler
I ran across a helluva deal on the HD work station/storage stand a couple of years ago. It has wheels and I can move my scoot all over the garage and even push it outside on decent days when I need the room in the garage.
I read once in this forum that it eliminates flat spots on tires that can develop from setting in one place all winter. I'm not too sure it's true, but it does make sense. Already having the HD jack, I couldn't pass up the price I stumbled across for the stand.
I've never covered my Road King with anything during the winter months. Hell, some days during the winter around here it actually gets warm enough to ride it...
