Quick question
Old Nov 11, 2011 | 11:44 AM
edteach's Avatar
edteach
Default Quick question
I have a 5x8 trailer exactly like the one in this photo. I am working on moving to Fla. and have this bike cradle also. I have never trailered a bike and my idea is to bolt a 4x8 sheet of OSB to the wire mesh of the trailer floor. I would then bolt the cradle to the OSB. Once thats done I can drive the bike onto the trailer and cradle and then strap the bike down. I would appreciate any ideas on what else to do to make it as secure as possible. Thanks.
Attached Thumbnails Quick question-19photo-lawn_trailer.jpg   Quick question-image_12005.jpg
Old Nov 11, 2011 | 12:04 PM
hyperfocal's Avatar
hyperfocal
Sounds good to me. Make sure you strap it down well.
Hyper
Old Nov 11, 2011 | 12:13 PM
TI06's Avatar
TI06
Someone told me once if using a utility trailer to tow your bike to mount some shocks to the under carriage. Supposed to help with all the bouncing which could cause problems. I have a utility trailer and it does get quite bouncy at times. I've never trailered my bike on it though.
Old Nov 11, 2011 | 12:27 PM
Misbehaven's Avatar
Misbehaven
Another thing to keep your eye on is the wheel bearing on the trailer. I can't that that the one you are getting bad but some of those utility trailers have been known to burn up bearings pretty quick. Just keep an eye on them.
Old Nov 11, 2011 | 12:36 PM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Do it just like you stated, and add some wood cribbing under the frame of the bike so as not to totally collapse your shocks when you tighten the four straps. After you secure the bike to the trailer it should not move at all. To test, shake bike with some vigor, trailer and bike should move as one unit. Remember to stop and check your straps after first twenty to thirty miles into trip to insure straps did not stretch to allow the bike to move independent of trailer. Also put hand on bearing hubs to check heat. Will get warm but should not get hot.
Old Nov 11, 2011 | 12:42 PM
oct1949's Avatar
oct1949
Think Ur trailer has them??, can't see for sure. If not bearing buddy''s are great to keep grease in the bearings.
Old Nov 11, 2011 | 12:48 PM
BillM's Avatar
BillM
Agreed. x10,000. I wouldn't own a trailer without Bearing Buddies.
Old Nov 11, 2011 | 01:32 PM
Breezybob's Avatar
Breezybob
Sounds like a good plan. Let me suggest that when you strap it down you use those nylon straps that look kinda like a figure 8; two loops with a shory piece in between. These go over the handle bars and the loops are where the tie-down hooks go. Ratchet straps will pull it all down tight and secure.
Old Nov 11, 2011 | 01:41 PM
aviator's Avatar
aviator
+1 on the cribbing under the frame. I towed my Fat Boy from Cali to TX using a 6X6 underthe frame and had no problems at all.
oh, I would NEVER use the handlebars as strapping points. go right to the frame.
Old Nov 11, 2011 | 05:03 PM
Jrsess's Avatar
Jrsess
Ditto!!!
