I'm pretty sold on jagg with the t stat adapter job. Now i just have to figure out how the hell to mount a highway peg.
Now go to your local NAPA/Motor Parts and Bearing store, and buy you some 400 psi rated hose. It's all I've ever used on my Sporty and FX, and I've never had a problem with hose failure.
I am sure both work but I have the HD Premium oil cooler kit on my 09 Streetglide. I liked the thermostat control feature, made sense to me.
The kit was easy to install but does move the oil filter out a bit so you have to be a bit more careful when replacing the oil filter, you don't want to disturb the crank position sensor.
My operating temps of the crank case oil run around 220f according to my digital dip stick!
