Breaking in a Harley
Old Jan 8, 2012 | 07:03 AM
SwitchHD's Avatar
SwitchHD
I was told by the dealer to "baby" it for the first 50, then watch rpms and vary the speeds/gears up to 500, after that, don't worry about it. This is also what's in the OM. ~2012 FLD Switchback.
Old Jan 8, 2012 | 02:54 PM
RANVIS's Avatar
RANVIS
Alot of good advise people. thanks.
Old Jan 8, 2012 | 06:42 PM
Jim Kraft's Avatar
Jim Kraft
With all of the roller brgs. in Harley motors, there is really not much breakin except for the rings to seat. It is a good idea to crank on the throttle for short bursts every so often to push the rings out against the cyl. wall. They should be seated by about 50 miles as good as they are going to get. After having said that, it is a good idea to very the rpm for the first few hundred just to make sure.
Old Jan 8, 2012 | 06:55 PM
heybaylor's Avatar
heybaylor
Just ride it .
You have no responsibilty to do anything ..
it is a precision machine , that is covered by knowledgable/honest
dealerships that have wonderfull techs.
no way you need to concern yourself in any way .
All will be fine , or HD will make you happy .
any problem that should occur will be swiftly, and with factory backing , be taken care of at absolutly no cost to you.
You may even be compensated for any inconvenience that might Occur..
signed .....ex Harley salesman
Old Jan 8, 2012 | 11:34 PM
DannyZ71's Avatar
DannyZ71
I followed the salesman's advise. Kept it below 65 for the first 100 miles. He didn't say anything about taking your time to get to 65 though. So sometimes it was slow and easy, sometimes I was there by the time I shifted into 3rd gear. Bike runs great now.
Old Jan 9, 2012 | 01:24 AM
TwiZted Biker's Avatar
TwiZted Biker
Oh man this begs to be chimed in on but ain't gonna waste the nails typing , nobody ever listens to the mechanic on this subject anyway .
Old Jan 9, 2012 | 04:28 AM
vizcarmb's Avatar
vizcarmb
I must be experiencing Deja Vu because somebody yesterday ask the same question
Do a search.
Old Jan 9, 2012 | 05:05 AM
harleyeglideman's Avatar
harleyeglideman
I would ADVISE you to do a search on this site or on Google where you will find some great ADVICE.
Old Jan 9, 2012 | 07:49 AM
dog155's Avatar
dog155
You will find like so many things in life is opinions on things vary widely.Listen to all you hear then decide for yourself what this new machine means to you.SUGGESTION!!!! Listen closely to the machinists and engine builders if you do not want to follow the manuals suggestions.Good Luck,my methods have always worked for me and I do build all my engines in all my machines.
Old Jan 9, 2012 | 08:12 AM
sgod1100's Avatar
sgod1100
I had to replace a piston in my bike over the summer (I only replaced one because this winter I'm redoing everything). I broke it in per "motoman's" process and when I took my pistons out there is a big difference in sealing between the two pistons. The one that i put in has no visible "burnt" marks beneath the piston rings. The other one that came in the bike when I bought in new has burn marks beneath the piston rings (indicating leakage). Granted the original piston has a lot more miles than the one that I replaced this past summer, but I rode the bike HARD all summer. I'll post some pictures of the two pistons
