Antenna End Jacks
Old Jan 12, 2012 | 12:17 PM
muccimr's Avatar
muccimr
Default Antenna End Jacks
The antenna jack that goes into my radio(20101 limited) is bent all to hell. I was able to get the end off but cannot find anywhere to get replacement. Trying to eliminate the need to pull tank and replace Antenna cable.
Thanks
Old Jan 12, 2012 | 12:55 PM
nvsteve's Avatar
nvsteve
I messed mine up and found one at Radio Shack.
Pretty sure this is it.
http://www.radioshack.com/product/in...ductId=2102835
Old Jan 12, 2012 | 02:07 PM
muccimr's Avatar
muccimr
Default Antenna end
Thanks, but wrong end. What I'm looking for is the end that goes into radio. The one I have is very flimsy.
Mike
Old Jan 12, 2012 | 03:55 PM
nvsteve's Avatar
nvsteve
Mike
That is the end that goes into the radio. Look at the tech specs and comments.
Old Jan 12, 2012 | 05:58 PM
muccimr's Avatar
muccimr
I must be blind, I cannot find anything on the antenna jack
Old Jan 12, 2012 | 08:10 PM
nvsteve's Avatar
nvsteve
You do not see this?
Old Jan 13, 2012 | 07:31 AM
muccimr's Avatar
muccimr
Yes. however, that is not the style used on the end that goes into the radio on my bike. Thanks..
Old Jan 13, 2012 | 08:59 AM
Retrax's Avatar
Retrax
muccimr,
The link nvsteve posted should be the proper part. If we are reading your post correctly, you are looking to replace the male end attached to the antenna cable which plugs into the female socket which is built into the radio. That should be a male Motorola style plug. You're not looking at a damaged CB radio cable end are you? Post a pic of what's damaged if you can and I am sure we can find someone around here that can help you find the proper replacement cable end.
Old Jan 13, 2012 | 12:09 PM
nvsteve's Avatar
nvsteve
Well ok but I have an HK radio in my 07 and it is the correct replacement.
Maybe they changed the connector or radio in 2010?
Old Jan 13, 2012 | 01:48 PM
Retrax's Avatar
Retrax
Same one for my 2009 FLHX. I thought the HK radios were the same in 2010 and 2011. Hopefully the OP can get the right repair part.
