Fork lock
Old Jan 26, 2012 | 07:14 PM
Sturgeon's Avatar
Sturgeon
Default Fork lock
Hey my fork lock is frozen.It's been a long time since I've used it and now it's not working. Any idea's? Tried wd and just about everything else.Thanks
Old Jan 26, 2012 | 07:24 PM
Blackfly's Avatar
Blackfly
How old is it ? Sorry to ask the obvious but did you move the forks while putting light pressure on the key ? Many won't lock when the fork is all the way over. Also WD 40 is not a great penetrant (or lubricant for that matter) WD stands for water disbursement. Get a good penetrating fluid and then oil.
Old Jan 26, 2012 | 07:25 PM
FroggyFatBoy's Avatar
FroggyFatBoy
PB Blaster or Thrust penetrant.. WD40 is for sewing machines and hinges.
Old Jan 26, 2012 | 07:27 PM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
It might help us if you tell us what Bike you have?
Old Jan 26, 2012 | 07:28 PM
purpledeuce's Avatar
purpledeuce
Sounds like you're forked
Old Jan 26, 2012 | 07:47 PM
Sturgeon's Avatar
Sturgeon
Yes Pur I am. Want to get it working thou. Sorry it's a 04 Superglide. Also tried some three in one. Moved forks back and forth while working with key didn't make any difference.So you think just better oil? Thanks
Old Jan 26, 2012 | 08:24 PM
wcsj55@yahoo.com
Soak it up real good with a good Penetrating Oil,let it sit long enough to work,then smack the lock with a rubber mallet a few times(repeat as needed) should help !!!
Old Jan 26, 2012 | 08:30 PM
Mal74's Avatar
Mal74
Are you sure you have the right key? If you bought the bike used, and the switch had been changed out, then the key you have for the lock won't work.
The switch on my '02 Heritage shorted out and I installed an aftermarket switch. So now I use 2 keys, one for the switch and one for the fork lock.
If that is the case for you, get an HD dealer to order a new key for your fork lock.
Old Jan 26, 2012 | 08:35 PM
zeus33's Avatar
zeus33
Big Kahuna HDF Member
Giggle it.
Old Jan 27, 2012 | 11:43 AM
monkeyboy22's Avatar
monkeyboy22
Originally Posted by zeus33
Giggle it.
This is not a laughing matter. He's trying to get out and ride. Try jiggling it after you put some penetrating oil in it. When it finally gets fixed, then you can giggle (but just a little bit).
