Free 103" upgrade
Old Dec 20, 2006 | 01:54 PM
hbski's Avatar
hbski
Default RE: Free 103" upgrade
anyone?
Old Dec 20, 2006 | 02:02 PM
wesd41's Avatar
wesd41
No. Its just a big bore job, like making 95" out of 88".
Old Dec 20, 2006 | 02:04 PM
wesd41's Avatar
wesd41
I think.
Old Dec 20, 2006 | 02:18 PM
Akitakoi's Avatar
Akitakoi
ORIGINAL: back again
I'm not aware of anything free at the steelers. Pretty sure that would go hand in hand with a cold day in hell.
Not true, my dealer is always trying to shove those free hotdogs down my throat.[:'(]
Old Dec 20, 2006 | 02:25 PM
SUPER01's Avatar
SUPER01
Coffee and doughnuts also free on the weekends.
Old Dec 20, 2006 | 02:55 PM
GreighWolf's Avatar
GreighWolf
ORIGINAL: hbski
Is opening the case required on a 2007 96" to go to 110"? It's not mentioned in the kit description:
Yes boring the case is required for clearance on the 110ci kit
see harley part nmber 94419-06 (it's the jig for boring the case)
Old Dec 20, 2006 | 05:54 PM
hbski's Avatar
hbski
ORIGINAL: GreighWolf
ORIGINAL: hbski
Yup, there it is:
Screamin' EagleÂŽ Case Boring Tool
The Screamin' EagleÂŽ Case Boring Tool takes the guesswork out of boring Twin Cam engine cases to accept oversize cylinders. Designed to be used with a heavy-duty 15" drill press or milling machine, the fixture holds and aligns the cases for accurate machining. Ideal for installing a new '07 Twin Cam 110 cubic inch Stage Kit or a '99-'06 race-use "bigger bore" 113 cubic inch stroker cylinders.
Old Dec 26, 2006 | 10:17 PM
cardboard's Avatar
cardboard
I thought about the 110cu motor till I found out I have to split the cases get a new flywheel, bearings, bore the cases and the price was around 6500, The 103 upgrade is around 1600 without heads, If you go with the 103 upgrade and the Screaming Eagle High Flow heads now were around 3200. Does anybody know the difference in the 96cu heads and the screaming eagle high flow heads for the 103 ? I'm told a 103 with heads and cams is a stronger running motor than the 110 CVO and on my FXWG its about all the frame can handle. Has anybody undertook this task on the new bikes yet, did you get any dyno results ? I'm looking hard before gettin it done. Thanks
Old Dec 27, 2006 | 01:45 PM
traveler's Avatar
traveler
110's stock from factory run crappy becasue of EPA. Open up the intake and exhaust, and re-tune, and then she'll scream!
103 is the way to go! Cheaper, and will have a bigger bore to offset the longer stroke. If you tear an engine all the way down, then you might as well do the Timken main bearing upgrade, Torrington cam bearing upgrade, forged rods, crank, wheels, and pistons, S&S reed valve, Fueling oil pump, CNC ported heads with larger valves, and upgraded valvetrain, cam chest clearanced for huge cams, gear drive cam kit, SE chromoly adjsutable pushrods, etc. about 6-7K done right!Then, you will wonder if you should have built a 124 S&S or 131 when you are done!!!!![&o]
So...stay at 96 or go 103, save a few bucks and just ride!
Joe
Old Feb 4, 2007 | 08:08 PM
madurodave's Avatar
madurodave
You have to split and bore the cases. I had the 110 kit installed on my '07 RKC. About $4500 total.
