07 softail clutch problem
Old Mar 11, 2012 | 04:29 AM
Terry101's Avatar
Terry101
3rd Gear
Default 07 softail clutch problem
Hi all, my clutch was working great, put screamin eagle oil in, still working great. Bolted up my 6 inch riser bars and new HD clutch cable and since then have never been able to get the clutch adjustment right.. Ive adjusted the clutch a dozen times.. Cable is seated correctly in clutch cover... Im baffled how to proceed ... Any tips would be great !!
Old Mar 11, 2012 | 12:30 PM
monkeyboy22's Avatar
monkeyboy22
Adjust the clutch and then the cable. If that doesn't work, make sure the cable is routed correctly into the ramp.
Old Mar 11, 2012 | 02:31 PM
Terry101's Avatar
Terry101
3rd Gear
Hi monkeyboy, cable into ramp is sitting right. I have doing clutch basket then adjusting cable last. Ive tried every position on the allen key rod then locked it but still cant get it right... Still baffled
Old Mar 11, 2012 | 06:57 PM
dynhd1's Avatar
dynhd1
Check the ramp/ball set up one more time , same thing happened to me.
Old Mar 11, 2012 | 07:54 PM
Terry101's Avatar
Terry101
3rd Gear
Cheers dynhd, ive checked and double checked the ramp ball, all ok in there. Done it all by the manual..
Old Mar 11, 2012 | 07:56 PM
Mikey 1450's Avatar
Mikey 1450
What is the problem with the clutch, slipping not dis-engaging?
Old Mar 11, 2012 | 08:51 PM
Terry101's Avatar
Terry101
3rd Gear
Hey Mikey, havin problems finding neutral...
thanoskazakos
Aug 11, 2018 08:48 AM
rdondes
Oct 23, 2013 08:16 PM
Terry101
Mar 11, 2012 08:39 AM
arbound1223
Aug 22, 2011 10:56 AM
jerryw618
Jun 17, 2011 05:32 PM
