Mixed Oils
Old Mar 21, 2012 | 10:37 AM
CHOPPIN' CHARLIE's Avatar
CHOPPIN' CHARLIE
Cool Mixed Oils
Ok, it was not me, but a DA friend did it and I voluntered to see what the Forum thinks. He was changing oil, or trying to, on a 96" Heritage 6 speed transmission. 5k and all fluids have been changed 3 times. Wanted to try Redline Gear 80w w/Shockproof. Drained tranny ok, new "O" ring, torqued to specs and proceeded to add the gear oil to the OIL TANK and when oil started to come out the OIL TANK, he knew something was wrong. Almost 3/4 quart had been added. See, said he was a DA. Imediatly drained the OIL Tank and refilled with Mobil 1. The oil tank was drained into a clear plastic container and the GEAR OIL separated to the bottom from the motor oil fast. The oil tank now is full of fresh oil. The motor has not been started. He now thinks of adding some Harvel Mystery Oil to the good oil and drain tank again, never starting the motor. Purchased another quart of Gear Oil and added to proper location. Refill oil tank and ride 2 or 3 miles, change oil and filter and hope for the best. Any thing constructive I can pass on to my friend? Thanks for much needed advise.
OK, I give up since y'all can tell it was me all along. After sleeping at the Holiday Inn last night, I called Redline and a friendly guy in California said it was ok just to drain the oil bag 1 time and what residue remaining would be ok. Other than 1 draining, the rest would be a waste of oil and recommended no further action required. He said their Transmission Oil was what he/I should be using instead of gear oil nohow. Is thicker and contains other additives than gear oil. I told him I got the gear oil info from the H-D Forum & he had no reply. He was very helpful with information. Thanks for your replies and help.
Old Mar 21, 2012 | 10:47 AM
chevele72's Avatar
chevele72
I would've let it sit with the drain plug out, but sounds like you've got it covered.
Old Mar 21, 2012 | 10:49 AM
myglide's Avatar
myglide
I would drain some more out of the oil bag and see if there is more Redline in it. I would call Redline and see if there would be any problem with the Redline and engine heat, flow etc.
Old Mar 21, 2012 | 01:01 PM
piasspj's Avatar
piasspj
Tell him the bike is ruined. Have him call me and I'll come haul it away.
Old Mar 21, 2012 | 01:09 PM
Shredding rubber's Avatar
Shredding rubber
K. Drain everything out. Go buy some el cheapo 20w-50 and a can of seafoam. Put half the can of seafoam in and the cheap oil. Run it for 100 miles. Drain. Do it again. Drain,new filter,and fuggettaboutit
Old Mar 21, 2012 | 02:11 PM
DDuess's Avatar
DDuess
I wouldn't do anything more then what was done. Add fresh oil and ride it. I wouldn't put any "cleaners" or additives in it. Chalk up the experience and forget it. Old Harleys used 60 wt and 70 wt oil in hot weather, some still use heavy straight wt in summer. A couple oz. of 80 in 3.5 qts of 20-50 wont change much.
Old Mar 21, 2012 | 02:53 PM
qtrracer's Avatar
qtrracer
Tell him to ride it. Don't do any more oil changes unless he just likes wasting oil. Till it's time to change the oil that is.
Old Mar 21, 2012 | 02:58 PM
Shredding rubber
Have any of you seen the msds sheet for shockproof. It's great for our transmissions,and I'm from the better safe than sorry school.
Do whatever you like. Ain't my bike
Old Mar 21, 2012 | 03:03 PM
jwhardin's Avatar
jwhardin
It'll be grand. Just ride it.
Old Mar 21, 2012 | 03:39 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
if you mix those two oils, they form an explosive substance, would sell it cheap to me and be glad I saved him!!!
gonna be fine!!
