Died while riding
Old Apr 13, 2012 | 05:07 PM
6speed51's Avatar
6speed51
My thinking is that this glitch or engine fart was caused by a slightly loose battery cable and a dirty air filter. Although I can't attribute either of the conditions to the problem I'm hoping that the combination of the two was the cause. What say you.
Old Apr 13, 2012 | 06:19 PM
gotnspikes's Avatar
gotnspikes
Originally Posted by FNGonaRK
Thank goodness it was the bike. I thought the forum was being haunted for a minute.
LOL, I thought this was going to be an interesting read from the title. Didn't even think about it being an issue with the bike.
Old Apr 13, 2012 | 09:12 PM
Darcon88's Avatar
Darcon88
6th Gear
I have had the same problem on my 05 deluxe, just died while riding a few times. After some checking , it turned out to be the kill switch. I took it apart and cleaned it and never had another problem. I'm not saying that it's your problem... just someting else to look at.
Old Apr 13, 2012 | 09:19 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Originally Posted by Robotech
Couldn't he also test this at home if he has a DC Voltmeter? On my Sportster I had a strange issue. Battery would charge but then act dead when I tried to start my bike. Hooked up a Voltmeter after charging overnight and it showed 12.7 Volts. Then I hit the starter to put a load on it. According to the Harley manual the voltage should drop to about 11V until the motorcycle starts. Mine dropped to 4V. Swapped battery and all was good.
Just figured if he had a Voltmeter he wouldn't need to take the battery anywhere.
I have no clue about anything electric Robo. So I am at the mercy of the guy with the tester but what you are saying sounds about right. But I have had a battery with a dead cell start the bike and then die about 10 minutes into the ride.
Old Apr 13, 2012 | 09:50 PM
Ragtop's Avatar
Ragtop
Originally Posted by dickey
No; Voltmeter will only tell the VOLTAGE the batery is putting out--it doesn't tell what the battery is capable of doing when something like starting is asked of it. Only a load test will tell that!
Most good meters are capable of checking amperage draw, but the connection must be made in series, and the probes must be connected in the correct plug on the meter.
An easier way to check draw would be to use the VDC setting as usual, and watch the voltage drop when trying to start the bike, if it only drops to 10 volts or so, the battery is probably ok, but if it drops down to 3 or 4 volts, it's bad, or there is a poor connection somewhere in the circuit, as the previous poster pointed out.
Old Apr 13, 2012 | 10:00 PM
SportsterBob's Avatar
SportsterBob
Do you have a gravity or vacuum feed fuel petcock?
Originally Posted by 6speed51
As I'm slowing down to turn onto my road the Road King, a 2006, just died. Electrics are on still, pulled to the shoulder and it started right up. Got to my driveway and died again as I slow down towards my shed. Started right up and I pulled into my shed and let it sit and idle.Shut it down, checked the ground off the battery and tightened it up, It wasn't loose but it wasn't tight, with a little force I could move it. The air cleaner was dirty, so I cleaned it up.Took it for a test and could not duplicate the problem. Earlier I noticed that the idle seemed high, now it does not. It only died when I let off the gas, would a dirty air filter starve the motor at low RPM's? Otherwise it never made any indication it was going to die, just shut off real quick-like.
Old Apr 13, 2012 | 10:40 PM
dstonemega's Avatar
dstonemega
Originally Posted by Maclugie
Yes, it would.
Shutup.
Old Apr 14, 2012 | 06:26 AM
6speed51's Avatar
6speed51
I don't have a petcock on my Road King, it's fuel injected. The kill switch is something to look into, cause that is exactly what happens. When you hit the kill switch all the lights stay on and the bike fires right back up. How about the System Relay behind the right side cover? Can something be sprayed into the kill switch to clean it up possibly? I never use that switch,it's always on, I turn the switch on the tank to shut it off and on.
Old Apr 14, 2012 | 08:14 AM
Darcon88's Avatar
Darcon88
6th Gear
I used the tank switch all the time too... never touched the kill switch until it died. After I cleaned the kill switch I have been using it every time when turning the bike on and off and never had another problem with the engine cutting out while riding. I never did try to spray the switch with anything while it was still on the bars. Contact cleaner would probably screw up the paint on the switch housing. Something milder maybe? Or just working the switch a bit might polish the contacts up enough.
Old Apr 14, 2012 | 08:29 AM
Ron750's Avatar
Ron750
Originally Posted by dstonemega
Shutup.
