brake light
Old May 13, 2012 | 07:12 PM
donberry54's Avatar
donberry54
Stage II
Default brake light
any body got any suggistion on how to fix the hand brake light swith, i have to push it foward for the light to go off, should i replace the handle or is there a adjustment on the switch .it is a 04 electric glide classic. hard to believe the handle could be worn that much with just 31000 miles on it
Old May 13, 2012 | 07:42 PM
BFREE's Avatar
BFREE
Replace the switch.
Old May 13, 2012 | 08:14 PM
dickey's Avatar
dickey
Don't replace the switch; there is nothing wrong with it. The problem is in your master cylinder; prolly needs to be rebuilt. Not allowing the lever to fully return. I speak from experience.
Old May 13, 2012 | 08:23 PM
RANGER73's Avatar
RANGER73
+1 ON WHAT DICKEY SAID. Rebuild the M.S. the spring inside pushes back the handle to push on the normally closed switch.
Old May 13, 2012 | 08:33 PM
73oldsman's Avatar
73oldsman
Have you messed with the hand controls or the brake master cylinder lately? If so you may have to make an adjustment. Look at the lever end and see if it's contacting the switch button. If not then you will need to take a piece of cardboard and squeeze the lever and insert the cardboard at the end of the lever near the master cylinder to hold it away from the button. Then, take the bolts loose and push the master assy. housing towards the hand control/brake switch. Hold while tightening. Remove the cardboard piece from under the lever and see if the lever now contacts the button.
Old May 14, 2012 | 03:44 PM
donberry54's Avatar
donberry54
Stage II
Default light switch
yes tried the bardboard trick it does make the light go off proably will have to rebuild the mc just bought it sat had to replace the battery in it and it was dated 2005 so i think the bike has been sitting for a while thanks for your help
Old May 15, 2012 | 09:29 AM
WillyHD's Avatar
WillyHD
Fixed mine with a pencil eraser and super glue. there is/was a rubber nub on the switch that wore off. Glued about an 1/8th of the eraser to the switch. Been working fine for over 3 years now.
supercrewser
Oct 18, 2012 03:29 PM
CSS_FXD
May 2, 2011 07:22 PM
Route66rider
Sep 19, 2010 09:26 PM
Kramer
Wheels/Tires
May 22, 2010 12:09 PM
fatking
Motorcycle Insurance Discussion
Jun 19, 2009 10:06 PM
