Rocker box replacement how to.
Old May 16, 2012 | 09:58 PM
meathead1134's Avatar
meathead1134
Default Rocker box replacement how to.
Is there a updated thread about rocker box gasket replacement for a 04 and up sportster. I'm gonna look for a manual but I'd figure I would try here first.
Old May 17, 2012 | 03:09 PM
WVHogRider's Avatar
WVHogRider
Yes, there's a few of them in the "Sportster Section" of this forum. You should try searching there for answers to both your threads.
Old May 17, 2012 | 03:13 PM
springer3's Avatar
springer3
Just what are you asking about how to replace rocker boxes?
How to do it? Its really pretty easy as far as doing if you have right tools and maybe a table todo it on!!!really only special tool you need is a torx wrench and go slow and watch out what your doing!!
Old May 17, 2012 | 03:37 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Youtube it, definately grab the manual it's one of your bibles now.
Old May 17, 2012 | 07:18 PM
Thundermug's Avatar
Thundermug
My '08 didn't use torx, it used allens.
Pull the seat off, pull the tank off, remove 4 allen bolts and remove top rocker cover...you might have to tilt and twist but it will comew off without scrathing..
Remove the other allen screws, BUT
BUT
BUT
loosen the rocker arms and remove first! the will warp if you don't!!!!
Just reverse the above to replace.
What I did was use Q-tips soaked in gas to get rid of some of the oil in the screw holes and use red thredlock on the screws and torque to....
dang....
I forgot....
the torque values....
Do not tighten the allen bolts without the proper torque values!!!
You can strip the threads...
Shoot, dude...
take it to the dealer!!!
Old May 17, 2012 | 07:19 PM
Thundermug's Avatar
Thundermug
Originally Posted by tampa fatboy
youtube it, definately grab the manual it's one of your bibles now.
absolutely!!!!
Old May 18, 2012 | 12:22 AM
springer3's Avatar
springer3
My spell check put torx it was suppose to say torque wrench!!
Old May 18, 2012 | 07:03 AM
WVHogRider's Avatar
WVHogRider
Do NOT use Red Loc-tite for the rocker bolts.......Unless you never want to get the rockers apart without F'n stuff up. The heads on the allens will end up stripping before you break the red loctite apart to remove those bolts and you'll need to chase the threads before re-installing the bolts before putting it back together. And I do not remember removing the seat to do my rockers, but yes, the tank should come off. As I said, there's several "How-To" write ups with pictures over on the sporty forum for this job. And yes, get the manual so you have all the torque values for the various bolts and the torque patterns.
rquest
Feb 7, 2013 07:27 PM
emperor wurm
Jan 13, 2012 05:47 PM
woody0404
EVO
14
Dec 24, 2011 12:13 PM
reise9633
Exhaust System Topics
Jul 23, 2011 01:06 PM
kgb44
Feb 8, 2008 08:29 AM
