Suicide clutch
Old May 26, 2012 | 05:09 PM
Jim Kraft's Avatar
Jim Kraft
I had an old 1942 "45" Flat Head when I was 16. It had the rocker clutch and hand shift on the tank. Not all that bad to ride except my front brake cable was broke. As said above it was a little tricky starting out on a hill when the light changed. Some fancy foot work as you went from left foot down and right foot on the brake, to right foot down and left foot on the clutch. Of course, when you are 16 you can ride anything. LOL.
Old May 26, 2012 | 06:43 PM
CSP067's Avatar
CSP067
I rode one for a bit back in the ... well a ways back. If you didn't have a front brake, you were in for some fun. A left turn from a stop was a real experience. You had to start to the right because your right foot was down, then transition to a left turn. Fun to ride though.
Old May 26, 2012 | 07:20 PM
AllenW's Avatar
AllenW
Only one I ever rode damn near killed me, didn't they call it a mousetrap clutch also?
Buddy who owned it seem to do well on it, just getting used to it I suppose.
Al
Old May 26, 2012 | 08:08 PM
pococj's Avatar
pococj
Al
Mousetrap was a device used with the first HD hand clutches. It was a "force multiplier" so that it didn't take as much force at the lever to operate the clutch.
Old May 26, 2012 | 08:29 PM
SportsterBob's Avatar
SportsterBob
Years ago my next door neighbor offered me to take his 45" Servi-Car around the block. I declined but he persisted. It had the tank shift-arm and a not stock foot clutch. I got it into 1st and slowly proceeded down the driveway. Shifted into 2nd with ease and brought it back within 3-minutes. Came to a crawl to shift back into 1st to creep up the driveway. I think it had a reverse idler but wasn't going to use it anyway. Three forward gears.
The owner took that Servi-Car to a bike show a few months later and won 1st place! More than a Machine!!!!
Old May 26, 2012 | 08:41 PM
QC's Avatar
QC
My father rode a trike as a Chicago P.D. Said he saw guys break their legs a couple times starting the things. All the other stuff was tricky as well, but at least he didn't have to worry bout falling over! Tank slap at any speed above 45 mph, too. Sheesh.
Old May 26, 2012 | 09:46 PM
brutalbrad's Avatar
brutalbrad
Old May 26, 2012 | 10:03 PM
firefighter616's Avatar
firefighter616
Adjusting the thing could bite ya, loved it on my pans
Old May 26, 2012 | 10:08 PM
DeJavu's Avatar
DeJavu
The old rocker pedal worked good but in the 60's and 70's many hand shift choppers had a modified clutch pedal that did work like a car and no front brake. This worked OK in the flatlands but of course if you came to a stop on a hill with the rear brake foot pedal stopping, no neutral and the other foot on the clutch you were in trouble. I converted my '56 pan chopper to hand clutch and the drum front brake that would atleast hold on most hills. I felt a lot more confident after that.
Old May 26, 2012 | 10:13 PM
DeJavu's Avatar
DeJavu
I remember the trick with the mousetrap was to wrap your fingers around the lever and use your body to pull back the first 1/2" then grab with your hand. It was easy once you got it moving over center.
