scraping main frame
Old May 27, 2012 | 12:31 AM
rich0924's Avatar
rich0924
6th Gear
Default scraping main frame
On my 2011 super glide custom I scrape the main frame. Can i adjust the shocks to prevent this, or does anyone have a better suggestion? thanks for any advice.
Old May 27, 2012 | 12:35 AM
Kowan's Avatar
Kowan
Most are setup on the soft side stock. They can be adjusted for a firmer ride.
Old May 27, 2012 | 01:26 AM
p51bombay's Avatar
p51bombay
Let me guess - stock pipes right? Passenger on board or shocks too soft on preload? You didn't scrape the frame even though it sounded like it. The rear pipe to the support bracket has a bolt that attaches the two and it points down - I'll bet that is what touched. Either you need to jack up the preload, get longer/better shocks or lighten the load.
Old May 27, 2012 | 10:26 PM
rich0924's Avatar
rich0924
6th Gear
I inspected the bike and verified i am scraping main frame and jiffy stand. will adjusting the shocks help prevent this?
Old May 27, 2012 | 10:33 PM
Cowpokey's Avatar
Cowpokey
Scraping it on what? Speed bump?
Old May 27, 2012 | 10:44 PM
TwiZted Biker's Avatar
TwiZted Biker
I don't mean this as insult or anything but whats your guys sizes ? Harley shocks tend to be soft and I've had to get heavier shocks for a few couples that where big people .
Old May 27, 2012 | 10:48 PM
rich0924's Avatar
rich0924
6th Gear
i scrape at both entrances to development where i live also i dont think weight is a factor 195lbs.
Old May 27, 2012 | 10:53 PM
rooti's Avatar
rooti
Put the shock on the 5 setting as described in your owners manual. You can get a spanner wrench for 12 bucks.
Old May 28, 2012 | 01:22 AM
lo-rider's Avatar
lo-rider
Slow down.
Old May 28, 2012 | 01:36 AM
TwiZted Biker
Wouldn't think so your under the average , check the manual and adjust them up settings over where you are now the tool is a good investment . Can always go more if still needed .
