Auto Clutch
Old Jun 7, 2012 | 12:07 AM
wschmidt's Avatar
wschmidt
1st Gear
Default Auto Clutch
I would appreciate hearing from anyone who has had experience with auto clutches on a Harley 88.
(left wrist arthritis)
Old Jun 7, 2012 | 01:14 AM
azblackbird's Avatar
azblackbird
I ran Rekluse autos on a couple of my dirt bikes. They're great for knarly trail riding. You still have to shift though, and they require you dial them in just right, or they'll either slip as you go through the gears, or will be too grabby at idle and stall the motor.
Here's a company I highly recommend if you decide to go that route. They have great customer support, and will work you through any problems you may have.
Old Jun 7, 2012 | 05:26 AM
Benway's Avatar
Benway
Dang, my wife would be interested in that clutch.
Funny, though, their "order now' link errors to a "Bad Request" page. That's comforting.
Old Jun 7, 2012 | 10:12 AM
Gypsylady's Avatar
Gypsylady
-Moderator-"Wench with a Wrench and Queen of Quips"
I have an EFM Autoclutch on my ride. I highly reccommend it. Basically, you send in your existing clutch & EFM does the mods & sends it back. Pretty simple to set up as well.
You shift just like normal but you no longer need a clutch lever. One thing, with this set-up your bike WILL start in gear & it won't just lunge & stall...It will roll! I know because it's a bitch to catch neutral on mine so I just leave her in gear...Just gotta go easy on the throttle on start-up!
Old Jun 7, 2012 | 11:38 AM
Benway's Avatar
Benway
If it takes off when you start it in gear, how do you not start it in gear and how do you then take off?
Old Jun 7, 2012 | 01:31 PM
azblackbird
When first starting up a bike with an auto clutch, and if the bike is in gear, the bike will creep a little bit due to the clutch basket oil not being warmed up. Just keep your foot/hand on the brake when first starting and you'll be fine.
Once the oil is warmed up, the bike will sit and idle when in gear. The key with an auto clutch is to always start it in neutral and let it warm up a little bit. Before starting, you can always tell if the bike is in gear by rolling it back and forth. If there's a little drag or it don't roll freely, then it is in gear.
Taking off with an auto clutch is a simple as putting it in gear and twisting the throttle. No need to engage/disengage the clutch lever with your hand. However it's there if you need it.
Old Jun 7, 2012 | 02:20 PM
Benway's Avatar
Benway
Thanks, my wife is a bit iffy about clutches, so this may work for her.
Old Jun 7, 2012 | 02:44 PM
TwiZted Biker's Avatar
TwiZted Biker
Edit , should have read them all Gypsy got to you already
Old Jun 7, 2012 | 04:11 PM
Gypsylady's Avatar
Gypsylady
Just make sure you're in neutral. I don't have a neutral light, so it's hit & miss. As long as you control your throttle, ya do fine!
Blackbird ran it down nicely!
Old Jun 8, 2012 | 12:25 PM
wschmidt's Avatar
wschmidt
1st Gear
Thanks for the come back. Looks like there may be another old dog trying to do a new trick, but delaying a surgery.
Ride Safe
