Great Bike Gear Softail Turn Signal Relocation kit
I am trying to find out if drilling or cutting or wormholes are involved here. The people that answer their email were not overly helpful.
You can see in my photo album how close my tag sits to my brake light.
Tom
It is fairly easy to look up inside the rear fender, from the very back of the motorcycle and see if there are any pre drilled holes in the fender in the center of the tag mount bolt pattern. Check it out.
I think he has it backwards. If the laydown tag mount is setup for relocating your rear signals to it, the mount will have a hole in the center of it to rout the wires. You will have to drill the hole in the fender to further rout thewires to the tail light housing. This is what Babs did if you look up his postings.
It is really no big deal to drill a hole into the fender,in the center of the license plate mount bolt pattern.
this holewill always be covered by the tag mount.I will attach a picture showing the signal wires coming into the brake light housing and where they plug in.
[IMG]local://upfiles/18321/28CD086A8682417BA4EC0857DA70B8BC.jpg[/IMG]
They said that there are pre drilled holes under the license plate mount?
I think he has it backwards. If the laydown tag mount is setup for relocating your rear signals to it, the mount will have a hole in the center of it to rout the wires. You will have to drill the hole in the fender to further rout the wires to the tail light housing. This is what Babs did if you look up his postings.
this hole will always be covered by the tag mount. I will attach a picture showing the signal wires coming into the brake light housing and where they plug in.
Apparently the only drilling that i have to do is to the Drag Specialites laydown bracket. That I am okay with. As for the predrilled holes... The only ones that I know of on the fender are the three holding the current license plate bracket on. I would assume that bracket would use those same holes. Or is it possible the laydown bracket only uses two and that leaves the third one open for running this wire.
The thing is... The people at foxleather have been awesome about my million and one questions. And Dave at EasyBrackets has been just as patient and helpful. Both those companies will get my business because they have been so cool without me even dropping a dime into their bank accounts.
great bike gear on the other hand... they need to learn a thing or two from these guys.
IF I get this thing rest assured that I will be photo documenting the whole dang install... hell... I may even video tape it. Cussing and all!
