Interesting pinging observation
Old Jul 20, 2012 | 05:09 AM
skully1200's Avatar
skully1200
Default Interesting pinging observation
So we had a few days where it was really hot. Riding on those days I noticed this. I occasionally get a very slight pinging in fifth gear, but at appropriate rpms for the gear. Can't say for sure what rpm as I have no tach, but definitely not lugging. I can putt along in fourth at a slower speed at considerably and admittedly too low rpms (lugging) and there is no ping. Seems it has more to do with the load on the motor than the rpms, but only does it in fifth gear, (five speed) and only when it's ***** hot outside. I'm not really concerned about it as it is very slight and only happens occasionally. I know the map I'm running in my PC isn't quite right for my cams, and I'm still waiting to get my dyno tune done. Hoping that clears it up. FYI, plugs and wires were new this spring, and I always run 93 octane gas.
Old Jul 20, 2012 | 06:29 AM
cleanimages's Avatar
cleanimages
I have a 2005 heritage and had same problem. After a Dyno its much better.... Still hear it occasionally but much less then before
Old Jul 20, 2012 | 06:36 AM
doorsidedown's Avatar
doorsidedown
the dyno will help, but may not eliminate it completely. you can tell the tuner about the pinging problem and if dumping a little
more fuel in that range doesn't help, retarding the timing slightly will. it fixed my pinging problem in 5th and 6th.
cajun1957a
Apr 15, 2020 11:41 AM
dynawg1
Engine Mechanical Topics
40
Mar 9, 2015 03:30 PM
TedMan
Mar 12, 2012 09:09 AM
FBFletch
Exhaust System Topics
17
Oct 22, 2011 06:45 AM
GScotty
Screamin Eagle CVO Models
Feb 14, 2010 04:03 PM
