Yu'll be fine... and the NEXT time yu strip a TORX, yu can goto an allen either SAE or metric... tap it in and remove carefully!!! Drilling is last resort, then helicoil.
if it's only a quarter of the thread, i wouldn't mess with helicoils, etc. just be careful when you are tightening that one down to not put much torque on it. well, for that matter, be sure not to put much torque on any of them, the spec only calls for about 8 ft/lbs.
i also use a little dab of anti seize on the threads as well.
you wanna know the real bugger of it all? once you had the head of the bolt drilled off, you could have turned the remaining piece of it out by hand (probably)......
Run a 1/4 20 tap in there to chase the threads Run a new bolt in and forget about it.
The torque on those is only 90-108 inch pounds....that ain't much
