chrome switch housing problems
Old Aug 5, 2012 | 04:17 PM
stryker847's Avatar
stryker847
2nd Gear
Default chrome switch housing problems
hi i have a 2005 wide glide and i bought hd chrome switch housings and after i installed them the start and run switch wont work. can anybody help in this
Old Aug 5, 2012 | 04:20 PM
bhaxton's Avatar
bhaxton
If you bought the cheap ones off of ebay they may have some casting flash inside of them. This stuff is like a razor and will cut into the insulation causing a short.
Old Aug 5, 2012 | 04:33 PM
stryker847's Avatar
stryker847
2nd Gear
no there HD switch housing everything looks ok. is there anyway i could have trip the security system
badwhine's Avatar
badwhine
Can you say, pinched wires? Sounds like you munged it.
stryker847's Avatar
stryker847
2nd Gear
bought from the dealer 148.00
Old Aug 5, 2012 | 04:34 PM
stryker847's Avatar
stryker847
2nd Gear
is that easy to do
Old Aug 5, 2012 | 04:46 PM
stryker847's Avatar
stryker847
2nd Gear
is there anyway to fix it
Old Aug 5, 2012 | 04:51 PM
Kowan's Avatar
Kowan
I'd pop the top back off and look for pinched wire/s.
If that's what is was found, I'd cut and solder using shrink wrap.
They are a snug fit with very little to no slack on the wiring. You might have caught a wire under the screw/clamp meant to route and hold the wires in the upper housing.
Old Aug 5, 2012 | 05:25 PM
Trailfndr's Avatar
Trailfndr
is that easy to do
VERY EASY to pinch a wire inside the housing.. Check that first.
Old Aug 5, 2012 | 05:43 PM
Twistnride's Avatar
Twistnride
It's easier to change cams than those fuking switch housings. Have fun................again.
