Primary chain tentionameters
Old Aug 29, 2012 | 04:54 PM
haak30's Avatar
haak30
Default Primary chain tentionameters
How do you know when they are worn out? I have 43k miles on my 09 train and was curious.
Thanks!
Old Aug 29, 2012 | 05:15 PM
Harley Tim's Avatar
Harley Tim
A lot depends on your driving beavior. If tou do a lot of "hole shots" or high revin' bangin' the gears; Your primary tentioner is going to wear faster.
I just changed mine w' 130K + Mi. on it , and it wasn't worn bad at all! probably could have waited another 15-20K. Just did it for grins 'n giggles, It's not a difficult task.
Hope this helps..
Best wishes....Tim(HT)
Old Aug 29, 2012 | 05:42 PM
haak30's Avatar
haak30
Are there any sounds, vibrations or any tell tale signs they are failing?
Old Aug 29, 2012 | 05:48 PM
TUCCI's Avatar
TUCCI
Check the primary and cam tensioners every 25k. The tensioners are plastic and you don't want any of it breaking off and jacking up your engine. Personally when I pull my primary case off to inspect the tensioner at 25k I plan to replace it with one that doesn't put strain on the bearings.......that's just me but I always side with caution. Just in case your wonder what I plan to replace it with, I'll show ya:
sbeamer
Jul 5, 2017 12:37 AM
JefFLH
Feb 14, 2010 07:03 PM
RoadHog659
Oct 2, 2009 08:15 PM
deadman77
Jul 13, 2009 02:52 PM
robster
Aug 5, 2008 09:34 AM
