Inner Primary Bearing Failure
Old Sep 3, 2012 | 12:29 PM
magna's Avatar
magna
I seem to remember there's a really looong thread on this problem somewhere.
Old Sep 3, 2012 | 12:34 PM
RDK09's Avatar
RDK09
Earlier this year i had the main tranny shaft and bearing go out at 21k on my 09, loud whirring noise in neutral with the clutch out. Ext. covered all $997 of it.
Old Oct 3, 2012 | 04:18 AM
Watch Guy's Avatar
Watch Guy
Default Did you have any other issues with this problem?
Like a rpm specific vibration or odd noises from the transmission pulley area?
Old Oct 3, 2012 | 08:14 AM
dolqiu's Avatar
dolqiu
Stage I
thanks for all the information guys
Old Oct 3, 2012 | 08:33 AM
Pondskipper's Avatar
Pondskipper
Originally Posted by SeniorChief56
at 43,000 miles. Luckily I have ESP....$181.19 in parts, $249.85 for labor. If you have whirling type noises when you downshift....this may be the problem
Odd how dealer costs spiral, I am doing my own, $50 in parts and nothing for labor.
Old Oct 3, 2012 | 08:47 AM
Sammi's Avatar
Sammi
Curious - does that cover the bearing, race, primary gasket, and fluids?
Sammi
Old Oct 3, 2012 | 09:08 AM
Pondskipper
Sammi
Primary gasket is fine to re-use, already been in there once to have a look, that gasket could be used half a dozen times, so it includes bearing, race and fluids, if it did need gasket then add $25 as that is what they cost after market.
Old Oct 6, 2012 | 09:44 AM
RDK09's Avatar
RDK09
Scraping sound from the primary in neutral with the clutch out at idle.
Old Oct 6, 2012 | 01:51 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
The 2006 dynas had the alignment dowels omitted from the cases. I had all of my cases, IPB, fluids, seals and rebuild labor covered by HD 2 years past my warranty.
All of the IPBs fail because of misalignment. The bearing in there could go 200,000 miles if it wasn't subject to misalignment by the case design. That design should have 2 thrust bearings versus the bearing they are using. Plus the trans bearings should be larger. As these motors develop more torque there will be many more failures.
Old Oct 6, 2012 | 05:12 PM
dawg's Avatar
dawg
TC 96's failures are probably somewhat attributed to the crappy tensioner. Try the Hayden M6.
