Finding Neutral
Old Sep 5, 2012 | 01:30 PM
  #31
CWDoc115's Avatar
CWDoc115
An old timer taught me this trick---
From 1st gear - Rev the engine a little bit, and as the revs wind down use a little pressure ( about 1/2 the pressure you would use to go to 2nd gear) to lift the toe shifter up and it should drop right into neutral.
I had quite some trouble with my trike, but using this trick finding neutral is easy now.
Old Sep 5, 2012 | 01:39 PM
  #32
zeus33's Avatar
zeus33
Big Kahuna HDF Member
My bike is still in 6th gear. I read it's bad to downshift.
Old Sep 6, 2012 | 08:28 AM
  #33
BuzzCap7's Avatar
BuzzCap7
My friend, do u know why it would be bad to downshift?
1) If u dnshift and rev the engine lie to 4K or higher that can't be gd. My dnshifting I do not even think it goes to 3K. Nothing straining the engine.
2) Also I had to replace (lost all my gears) the Clutch Hub (what the spline goes into that drives the rear wheels) that may have to do with constantly, I mean ALWAYS downshifting.
3) I think dnshifting saves ur brake pads.
BuzzCap7
Old Sep 6, 2012 | 10:34 AM
  #34
zeus33's Avatar
zeus33
BuzzCap7
I was just just jokin buzz.
Old Sep 6, 2012 | 11:18 AM
  #35
Lakerat's Avatar
Lakerat
When you take it to the dealer, ask the service manager to prove that neutral can be found on your bike without a problem, sitting still while at idle. If he can't do it, see if one of their techs can.
Old Sep 6, 2012 | 02:00 PM
  #36
TheGeek's Avatar
TheGeek
It could be where the shifter rocks (pivots). You may have to take it apart, clean it, lube it with wheel bearing grease, and slip it back together. If I remember correctly, it was around 1K miles I had to do this, never had to do it again.
Old Sep 6, 2012 | 02:12 PM
  #37
Jackie Paper's Avatar
Jackie Paper
It is more a learning process then anything. However I assume your are always going from 1st up to neutral? If it jumps by always go back to low and let the clutch out ever so slightly to make sure it's all back in proper position and then pull in clutch and lever up again. Once your bran and foot get connected it is quite easy. Six speeds are more difficult then 5 since the gate is smaller.
Old Sep 7, 2012 | 09:28 AM
  #38
BuzzCap7's Avatar
BuzzCap7
Gotcha my friend. Thanks.
BuzzCap7
Old Sep 7, 2012 | 10:09 AM
  #39
brenn's Avatar
brenn
Originally Posted by skratch
i'm assuming you have the engine off?
Yes. I assumed he meant finding neutral before starting it. That's about the only time I ever put it in neutral.
Old Sep 7, 2012 | 11:29 AM
  #40
Scaredofrain's Avatar
Scaredofrain
I found a neutral tha I'm not using in the back of my garage. If you pay for the shipping I'll let you have it!
casique
Aug 4, 2014 07:39 PM
jp2code
Jun 28, 2012 05:06 PM
folsomRodglide
General Topics/Tech Tips
Jul 1, 2011 03:24 PM
johnnyholmes
Apr 26, 2010 09:09 PM
bobbav
19
Aug 15, 2008 09:01 PM
